I just replaced my Coupe hatch weatherstrip with the one that Bill C sells. After applying it I discovered that the hatch would not close. I climbed inside and watched the way the Hatch's latch engaged the strike on the body of the car. I discovered that if I took the strike off the car, banged it flat with a hammer (so that it would rest about 1/2" closer to the back of the car from it's original position) and bolted it back in sitting a bit higher than originally, the hatch closes and locks fine.
Hmmm... I just looked at the parts catalog. It appears from the diagram that the strike is SUPPOSED to be flat. I guess it was tweaked earlier in it's life to make up for the old, worn-flat weatherstrip? Anyway, the position of the strike (up/down and forward/back) seems to be the key to getting one's hatch to close well.
www.honda600coupe.com
New Coupe hatch weatherstrip, and adjusting the latch
Re: New Coupe hatch weatherstrip, and adjusting the latch
Hi Steve;
Glad to hear you were able to work it out. Will you be joining us for the On Line Car Show?
> Steven Michelsen
> [mailto:stevenm@...]
> Tuesday, November 16, 2004
> 11:58 AM
> Honda group - anzhonda600owners
> [anzhonda600owners] New Coupe hatch weatherstrip, and adjusting the > latch
> that Bill C sells. After applying it I discovered that the hatch would > not close. I climbed inside and watched the way the Hatch's latch > engaged the strike on the body of the car. I discovered that if I took > the strike off the car, banged it flat with a hammer (so that it would rest > about 1/2" closer to the back of the car from it's original position) and > bolted it back in sitting a bit higher than originally, the hatch closes and > locks fine.
> appears from the diagram that the strike is SUPPOSED to be flat. I guess > it was tweaked earlier in it's life to make up for the old, worn-flat > weatherstrip? Anyway, the position of the strike (up/down and > forward/back) seems to be the key to getting one's hatch to close > well.
> Steve
