Re: [2cylinderhondas] window slider guides and muffler help
Hi Mike;
For the window wheels, I use the door (as in the door to your closet or
patio door runner) slider wheel repair kit you can pick up for a few bucks
at the local hardware or home improvement center. I cut them to make them
fit into the channel and grind off the rivet, and using the bolt that comes
with it, bolt it in place. Works fine lasts a long time. Don't forget to
lube it up. As for the muffler, you will most likely be replacing the pipe
from the connector by the front wheel to the rear. I have used several, but
what it comes down to is what the muffler shop has on the shelf.
