Name That Part
Name That Part
Driven Sprocket Thrust Washer!!!
Re: Name That Part
Both Larryn600 and riceburner006 had the correct answer, Thrust Washer, to
the Driven sprocket or transmission. This was a fairly easy one, but the
importance of this washer will give many more miles if it is the proper
thickness. As the drum to the clutch mounts to the hub this thrust washer
is holding against the shaft. The thickness of this washer should be no
less than 40 thousands thick. And, if there is still to much room between
the circlip and the thrust washer (more than .002 then look at the hub.
Will it work with more clearance, sure, but then there is more movement.
More wear and you will be repairing it sooner.
so Larryn600 is the first winner.
Name That Part
Name That Part will resume again tomorrow. My server is down for
maintenance and I can't get to my e-mail.
