I apparently miscounted the teeth on the gear yesterday...15 teeth
tells me this is for the constant mesh trans, where the full synchro
trans has a speedometer gear with 14 teeth...if you put the early gear
in the late trans, it will only work a short while before it has a
nasty loss of teeth due to insufficient clearance!!
Fwd: Name That Part #6
Re: Fwd: Name That Part #6
Evidently some one does not have both sets of speedometer gears in front of
them. So lets see if there are any other answers coming in.
