It seems that you have it figured out, but one thing I didn't see mentioned is the float, yours looked a bit chewed up. Make sure it still floats.
As for the power source, it runs on body feed which is 12V. And, as was mentioned, just hook up a volt meter up to it and it should register.
Caution, don't use silicone gasket sealer on the gasket. If it falls into the tank (the screws will push it through the holes) it can plug up the tank.
And speaking of tanks, if your having trouble getting the Gas nozzle into the Sedan Filler I have found a 1 inch Dia. 12 inch long vinyl tube fits the filler tube and the gas nozzle goes right in. Caution, push the vinyl tube about 3 inches into the filler tube then watch how much you are puttin in and that you don't fill to fast or to much. Out here in California the EPA has a rubber sleeve that is supposed to capture the fumes. All it does on a Honda 600 is prevent us from getting gas in our tank.
Tap the vinyl tube a few times to get out all the remaining fuel and place it in a bag in the trunk of you Sedan. It works great.
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > Matt Timion > Sent:
> Sunday, April 23, 2006 8:02
> [2cylinderhondas] need urgent help with fuel sending unit
> That's good to know for future replacement
> issues.
> I managed to disect the unit and solder on a new
> wire connection without much issue. It seems to be working like a charm > now. :)
> > reerw
> > rewrew
> > Sunday, April 23, 2006 7:59
> > PM
> > Re: [2cylinderhondas] need
> > The honda scooters, spree and aero use a similar sending unit > > i use one on my z600 > > Matt Timion > matt@...
> > > Thanks greg.
> > > I'm going toclean it up a bit and try to get
> > > it working again today. Does anyone know what voltage this thing > > > uses?
> > > > ----- Original Message -----
> > > > From:
> > > > Greg
> > > > Sikes
> > > > To:
> > > > Sent:
> > > > Sunday, April 23, 2006 7:22
> > > > AM
> > > > Subject:
> > > > It is all there, except your ground wire is broken off the round > > > > terminal next to the spade terminal. I had one that, the arm was rusted > > > > solid, but spraying it with lots of WD-40, and GENTLY working it until > > > > it freed up, it actually worked when I got done with it.
> > > > Greg
> > > > Matt Timion > > > matt@...
> > > > wrote:
> > > > > When
> > > > > I purchased my n600 the fuel sending unit never reported a thing.
> > > > > Today I dropped the tank and here is how the unit looks:
> > > > > http://images6.theimagehosting.com/albu ... sender.jpg > > > > > From > > > > > what I can tell it is missing a part. Hopefully I'm wrong about > > > > > that.
> > > > > I'd like to have this car up and running by the end of > > > > > the week, so that > > > > > includes a new sending unit, or getting this one > > > > > working. Can anyone tell > > > > > me if the wires can be connected to > > > > > the two connections shown? Every > > > > > pictures I've seen of a > > > > > sending unit has a roundish top on it, unlike this.
> > > > > If this
> > > > > appears to be a little too broken to use, does anyone have a working
> > > > > unit they can sell me and ship out on monday? Or, is there > > > > > an aftermarket > > > > > unit that will work?
> > > > > Thanks in
> > > > > advance. I'm REALLY close to getting this puppy registered and > > > > > on > > > > > the road. I can't wait to drive it around > > > > > town.
> > > > > Matt Timion
