Re: [2cylinderhondas] Re: Rear shocks
If you go to the tuner shops the 66 - 69 maybe 72 DATSUN small pickup has had a lot of after market shocks.  The front shocks will bolt in (but you have to remove the cross plate with bolt holes.  The VW shocks have to be ground down on both sides of the lower mount and you have to flatten the body seam about 2.5 inches.  Stiff, yep.  loose teeth will fall out, but after a month or so you will enjoy the better truning (less body roll) capablility it gives.
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > wanna600 > Sent:
> Thursday, August 10, 2006 8:54
> I ended up with the VW shocks on back of my n600. It wasn't a plug > n > play operation, but I don't remember it being horrendously bad > either.
> The shocks I ended up with are made by Boge, and they are the > softest > shocks I could find. Most of the aftermarket shocks have way too > much > dampening for the light weight of a n600 rear end and result in > an > overly stiff ride.
> If you can't find them mail order, go to you
> local VW shop... they'll
> most likely have them in stock.
> -Miles E.
> "Matt Timion" wrote:
> > I know this has been
> covered, but I thought I'd ask for a little
> more information.
> > My z600 needs new rear shocks. I was thinking of putting the > shocks > from the n600 into the z600 and getting new shocks for the n600.
> Odds
> are I'll be driving the n600 more, so I'd rather have the new > shocks > on the n600.
> > So, I know that I can get front shocks
> from a 69-71 VW and they'll
> fit with a little modification. I've also read
> that I can get Datsun
> 520 shocks and they'll fit, although I'm having a
> difficult time
> finding them. I've seen a few people have Koni shocks on
> their n600,
> although I don't know the model, information, etc.
> > This is a link to tirerack's shocks for a 1970 Beetle. Can > anyone > tell me if they will work?
> http://www.tirerack .com/suspension/ Susptabl. jsp?autoMake= Volkswagen& autoModel= Beetle&autoYear= 1970&autoModClar =&category= Shocks&scat= Shocks&category= Springs&scat= Springs&category =Kit&scat= Kit&category= CoilOver& scat=CoilOver& category= AdvSuspSys& scat=AdvSuspSys& category= AntiRoll& scat=AntiRoll& category= BootMount& scat=BootMount& brand=all& perfcat=premium& perfcat=perf& perfcat=track
> Can anyone give a link as to where I can obtain new shocks that will > work?
> Has there been a writeup on replacing them?
> > [Non-text
> portions of this message have been removed]
