Noise near passanger side inner cv/diff housing.
rick_lowe2002
Post by rick_lowe2002 »
Hi,
Just bought this car and drove it 100 miles. Had been making an
intermitent noise. Pulled it up on ramps and ran the motor and
listened carefully with a rubber hose. It is comming from somewhere
in the casig where the passanger side cv axel goes into the diff
housing. I think it is on the top side.
It is a distinctive knocking noise.
Any ideas what this may be?
Thanks in advance!
Rick
JOHN BURKHIMER
Re: Noise near passanger side inner cv/diff housing.
Post by JOHN BURKHIMER »
If the noise is a "clicking" sound, and gets louder as you go around a turn, it is possible that the CV joint is bad.
thanks
john
> rick_lowe2002
> Thursday, October 05, 2006 8:46
> [anzhonda600owners] Noise near
> Hi,
> Just bought this car and drove it 100 miles. Had been making > an > intermitent noise. Pulled it up on ramps and ran the motor > and > listened carefully with a rubber hose. It is comming from > somewhere > in the casig where the passanger side cv axel goes into the > diff > housing. I think it is on the top side.
> It is a distinctive
> knocking noise.
> Thanks in
> advance!
> Rick
> Checked by AVG Free
> Edition.
> Version: 7.1.407 / Virus Database: 268.12.13/463 - Release Date:
> 10/4/2006
rick_lowe2002
This is absolutley not the cv joint. It is making the noise while the
car is in NEUTRAL.
Rick
riceburner006
Post by riceburner006 »
--- In anzhonda600owners@yahoogroups.com, "rick_lowe2002"
Hello! Did you listen on the reverse cover where the dipstick is?
I'm thinking the clicking could be a bad ball bearing on the
countershaft,which is under that cover. riceburner006
> Hi,
> Thanks in advance!
> Rick
rick_lowe2002
Yes I did. The sound is more pronounced near the top of the cv
axel/diff housing. I spoke to an expert yesterday and he said is
sounds like a bearing near the differantial. Says it is not that
common but he has seen this and it WOULD make this noise while in NEUTRAL.
Rick
