Other Factory options were Sedan Clocks, roof racks, half folding forward rear seats, pop-up antenna, fog lamps and exhaust tips. Your radio is an after market radio. But the speaker for the Coupe goes under the upper center of the dash. However, I guess you could bracket two 8 inch box speakers on each side of the body and they would act like head phones.
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > h600 > Sent:
> Sunday, December 17, 2006 8:54
> [2cylinderhondas] radio
> i did know cutting, I will put am radio in my sedan if you brake jamnut on > vol&tun they adjust at angle for coupe.and i used the plastic spacers that > where with radio.The instulation looks factory.My dealer said early honda's > radio's was a dealer option not factory showed no radio or speakers in his > books.I did see pic's of 8 ohm 3.5 watts on yahoogroupes. all i got is > ideas where two speakers would go on coupe.I posted a pic of my radio > installed but it was automaticly removed i will try again > ----- Original > Message ----- > From:
> billmyong@earthlink .net
> Sent: Sunday, December 17, 2006 8:38 PM
> Subject: RE: [2cylinderhondas]
> radio
> Well, if you put a Sedan am/fm radio in a coupe you had to do a > bit of > chopping, (Coupe radio's are not as wide as a Sedan radio) the coupe > speaker > (1) is under the center section of the dash above the radio. Where > is your > AM Coupe radio?
> ]On
> Behalf Of h600
> Sent: Sunday, December 17, 2006 12:03 PM
> got a AM/FM radio that came with an 600 sedan
> and speakers are gone.
> anyway i put radio in my coupe.Coupe had a AM radio
> with 4ohm 3watts
> speaker.What speaker's went with am/fm and where did car
> dealer's install
> both speakers in a coupe here is a picture of
> radio
