successful engine swaps?
landyachtcruiser
I've got a non-running 1972 AZ600 coupe. Would it make better sense
(financially and from the standpoint of every day use) to swap drive
trains with a more common/powerful make model than to rebuild the air
cooled unit? I live in Wisconsin, and the parts stores look at me
like I'm making things up when I ask what they have...
almightydoan
Re: successful engine swaps?
--- In anzhonda600owners@yahoogroups.com, "landyachtcruiser"
require fabrication and other tid bits. But I don't know much.
Hondawizard75 on ebay (Mike)sells rebuild engines and might have the
parts you need, http://www.honda600shop.com/. Or you could check out
this site, http://www.cmsnl.com/honda-cars_model7892/. If they have
what you need, it's going to be expensive.
-MD
I've heard that an engine swap would be very expensive as that would> I've got a non-running 1972 AZ600 coupe. Would it make better sense
-MD
cleanciviccvcc
--- In anzhonda600owners@yahoogroups.com, "almightydoan"
ill be attempting a swap within the coming months, im having such a
hard time finding rebuild kits i mean all i wanted was gasket but
have been given little input so i've decide that i'll fabricate a
mounting system for a newer honda engine. I figure a mini cooper can
accept a new honda engine than a little enginuity can be applied to
my 600s, anyways goodluck.
im in the same boat as well, granted i can't leave well enough alone> --- In
> parts you need,
> this site,
If they have
> -MD
Reply to all;
If money is not a question, then neither should your desired engine swap. But if your looking for daily transportation then there are plenty of winter cars up there for one tenth the price.
> cleanciviccvcc
> Thursday, August 16, 2007 11:36
> [anzhonda600owners] Re: successful engine swaps?
> "almightydoan"
> "landyachtcruiser"
> > > I've got a non-running 1972 AZ600 coupe. Would it make > better > sense > > > (financially and from the standpoint of every > day use) to swap > drive > > > trains with a more common/powerful > make model than to rebuild the > air > > > cooled unit? I live in > Wisconsin, and the parts stores look at me > > > like I'm making things > up when I ask what they have...
> > I've heard that
> would
> > require
> > Hondawizard75
> the
> > parts you
> need,
> http://www.honda600 shop.com/ .
> Or you could check
> out
> > this site,
> http://www.cmsnl. com/honda- cars_model7892/ .
> If they have
> > -MD
> well enough alone
> having such a
> gasket but
> have been given little input so i've decide that i'll fabricate > a > mounting system for a newer honda engine. I figure a mini cooper can
> accept a new honda engine than a little enginuity can be applied to > my > 600s, anyways > goodluck.
Have you written Bill Colford at billmyong@... regarding a gasket
kit for your engine? He makes and sells them. When you write him be as
specific as possible. If you need a parts catalog to get numbers from, you
can download it from my site at
http://www.honda600coupe.com/Manuals,_b ... ments.html
Good luck,
Good luck,
cleanciviccvcc
i want a new engine for racing and reliabilty and possibly for the
shear novelty, the only resource i lack is time.
, wrote:
> Reply to all;
engine
plenty of
]On Behalf Of
cleanciviccvcc
> Sent: Thursday, August 16, 2007 11:36 PM
> Subject: [anzhonda600owners] Re: successful engine swaps?
, "almightydoan"
> sense
> drive
the
> air
at me
> would
> the
> > parts you need,
Or you could check
> out
> > this site,
If they
have
> > -MD
alone
a
can
to
Almighty Doan
If you want an new engine for racing, by all means do it. Just let me see how you get it done after you're through. If you want it for racing only, then you'd probably be able to put in a 600RR engine or even a Hayabusa. You just wouldn't be able to go reverse. :D I'd like to put in a more potent engine in my n600 when I have the funds. But as for now, I'm going to get some performance carbs or go turbo.
-MD
cleanciviccvcc wrote:
-MD
> i want a new engine for racing and reliabilty and possibly for the > shear novelty, the only resource i lack is time.
> , wrote:
> > Reply to all;
> > If money is not a question, then neither should your desired > engine > > swap. But if your looking for daily transportation then there are > plenty of > > winter cars up there for one tenth the price.
> > [mailto:
> ]On Behalf Of
> cleanciviccvcc
> , "almightydoan"
> > > wrote:
> > > > I've got a non-running 1972 AZ600 coupe. Would it make better > > sense > > > > (financially and from the standpoint of every day use) to swap > > drive > > > > trains with a more common/powerful make model than to rebuild > the > > air > > > > cooled unit? I live in Wisconsin, and the parts stores look > at me
> > > I've heard that an engine swap would be very expensive as that > > would > > > require fabrication and other tid bits. But I don't know much.
> > > Hondawizard75 on ebay (Mike)sells rebuild engines and might have > > the > > > parts you need, > http://www.honda600 shop.com/ .
> Or you could check
> > out
> > > this site,
> If they
> have
> > > -MD
> > im in the same boat as well, granted i can't leave well enough > alone > > ill be attempting a swap within the coming months, im having such > a > > hard time finding rebuild kits i mean all i wanted was gasket > but > > have been given little input so i've decide that i'll fabricate a > > mounting system for a newer honda engine. I figure a mini cooper > can > > accept a new honda engine than a little enginuity can be applied > to > > my 600s, anyways goodluck.
Ready for the edge of your seat?
Check out tonight's top picks
on Yahoo! TV.
ask around for a Rocketdyne H-1powerplant. excellent specific impulse characteristics.
might even fit. you may need to install a larger fuel tank though...
> I've got a non-running 1972 AZ600 coupe. Would it make better sense > (financially and from the standpoint of every day use) to swap drive > trains with a more common/powerful make model than to rebuild the air > cooled unit? I live in Wisconsin, and the parts stores look at me > like I'm > making things up when I ask what they have...
Yahoo! oneSearch: Finally,
mobile search
that gives answers
, not web links.
Almighty Doan
Isn't that some sort of rocket engine for a space craft? At least that's what I found when I googled it.
> landyachtcruiser
> > I've got a non-running 1972 AZ600 coupe. Would it make better sense > > (financially and from the standpoint of every day use) to swap drive > > trains with a more common/powerful make model than to rebuild the air > > cooled unit? I live in Wisconsin, and the parts stores look at me > > like I'm making things up when I ask what they have...
> mobile search that gives answers
> , not web links.
mobile search
that gives answers
, not web links.
cleanciviccvcc
yeah it has to be if hes talking about specific impulse. i rember
seeing some doode doing it in a silver z from new zealand just google
image jet powered honda.
