starts up fine. but for some reason out of no where I tried to start
it the other day, the starter woundnt crank. the starter gear seems
to get stuck in the
tranny. I took out the starter to give it a test, it spins fine and
the gears moves up and down, but when I put it back in it will get
stuck.. so i went and have the starter rebuild for $90
and its still the same problem.
could it be the transmission? all the gears on the transmission are
fine,its weird when i put the starter back in the tranny and crank it
the starter would get stuck, jam and if i hold it for long time i
will see smoke comming from the starter. oh and i did crank the
engine with a a wrench and it spins fine and flywheel tooth are all
ther. maybe the flywheel is loose? please
here are the picture i took to show you if you see anything diffrent.
http://i11.photobucket.com/albums/a166/ ... ure012.jpg
http://i11.photobucket.com/albums/a166/ ... ure010.jpg
http://i11.photobucket.com/albums/a166/ ... ure011.jpg
http://i11.photobucket.com/albums/a166/ ... ure007.jpg
http://i11.photobucket.com/albums/a166/ ... e008-1.jpg
also anyone here know where i could get another starter for my 72
z600?
> THANKS!
> Tran Nguyen
