Quite the project you are wanting to take on.
Living in the UK, I would think a Mini-Cooper would have been your choice for a mini-car good restoration project. If you are going to use a Honda 600, fitting 2 adults into the back seat will be a problem and you will need to lengthen the car. These cars are uni-body in construction and there is no frame under the chassis. The cars are front wheel drive and they have a 2 cylinder engine under the hood. You will not have much room in the existing engine compartment and will probably need to do some major modifications to fit your diesel engine and transmission. The Honda 600 engine and transmission were contained in one integral housing.
The 600 sedan would give you a little more room in the engine compartment while the Z600 coupe with its sloping hood reduces the available room. If you take on the project with a Honda 600, keep us informed of your project and post pictures.
Good luck,
Planning your summer road trip? Check out AOL Travel Guides .> 1) be
> as small and light as possible, while fitting 4 adults. Front > seats to fit > 6'4 tall person, rear seats to fit 5'10 person. I can > lengthen the body 6" > if a suitable car is appropriate but just > doesn't have the rear legroom - > no problem.
> 2) Mechanicals don't matter as I'll likely be fitting a modern > small > diesel engine and automatic transmission.
> 3) it has to have two
> wheels on the front for handling (I quite like
> or would consider modifying
> to single rear wheel, but must have two
> front wheels)
> 4) it's a bit of
> a fuel economy project therefore aerodynamic
> potential (the basic outline
> of the shell, or the ease at which I can
> make it aerodynamic) is
> important, as is frontal area (smaller the
> better) and weight (lower the
> better).
