Re: [2cylinderhondas] Ceat Tires
Yea know.  I would look the front end over and make sure there are no bent or damaged areas.  Then use a tape measure and make a horozantal chalk mark on each tire two inches off the ground.  Loosen the tye rod nuts and measure the distance at the marks on the middle tire tred, now roll the car back and measure the same chalk marks from the rear of the tire from the same tread.  Move the tye rod arms equally on each side until the measure is the same by measuring the chalk marks front and back.  Toe in is so slight that dead on is almost there.  Besides, I paid $25.00 bucks to watch an alignment shop do the same thing.  Yea, it was a long time ago, and my tires are still running strong.
> Tuesday, June 10, 2008 1:10
> Back when I got my very first Honda 600, I was 19, my dad thought he
> would do me a favor and bought me a set of Ceat brand tires. They > were > bias ply and the worst tires I have ever had to this day. Even > my rock > hard Michelin snow tires were a better ride!
> I would avoid any Bias
> ply tires unless you are trying to do a 99
> point restore on a 1970 or
> earlier car. The original tires were 5.20
> x 10 Bridgestones.
> Kevin
> - you should take your car down to Lloyd's in Santa Cruz, they > used to do > my alignments. They could also show you what's bent in > your front end.
> scott lesniak
> > I just
> bought 30 tires if anyone needs a set let me know I would > like to get 38 > apiece for them > > I think they are Ceat Tires > > really nice > tread pattern
> > --- On Mon, 6/9/08, Kevin
> misterpoopoohead@ ... wrote:
> > From: Kevin
> > Subject: [2cylinderhondas] New tires are
> wearing out fast!
> Date: Monday, June 9, 2008, 2:00 PM
> > Hi Gang,
> > I put new tires on my car
> less than 1000 miles ago and they are
> already
> > noticably worn in
> the front. The front end may not be perfectly
> aligned
> > but I
> wouldn't expect the tires to get worn out in so few miles.
> > I
> bought the Kumho 145/8010's. These are T rated tires. They ride > nice
> > but they are not going to last to long.
> kev
Kevin Lister
Post by Kevin Lister »
It seems like my car has more problems than just simple alignment. I've tried the trick with two tape measures, etc, and it was so far off when measuring that doing it by eye was more accurate. One of my front tires sticks out from the side of the car farther than the other. So, something must be up!
Tue, 6/10/08, billmyong@...
> From: billmyong@...
> Subject: [anzhonda600owners] RE: [2cylinderhondas] Ceat Tires > To: "Anzhonda600owners" , 2cylinderhondas@yahoogroups.com > Date: Tuesday, June 10, 2008, 9:13 PM
> > 2cylinderhondas@ yahoogroups. com [mailto:2cylinderho ndas@yahoogroups .com] > > On Behalf Of > > Miles > > Sent:
> > Tuesday, June 10, 2008 1:10 PM
> > Back when I got my very first Honda 600, I was 19, my dad thought he > > would do me a favor and bought me a set of Ceat brand tires. They > > were bias ply and the worst tires I have ever had to this day. Even > > my rock hard Michelin snow tires were a better ride!
> > I would avoid any Bias ply tires unless you are trying to do a 99 > > point restore on a 1970 or earlier car. The original tires were 5.20 > > x 10 Bridgestones.
> > Kevin - you should take your car down to Lloyd's in Santa Cruz, they > > used to do my alignments. They could also show you what's bent in > > your front end.
> > Miles
> > , scott lesniak
> > > I just bought 30 tires if anyone needs a set let me know I would > > like to get 38 apiece for them > > > I think they are Ceat Tires
> > really nice tread pattern
> > > --- On Mon, 6/9/08, Kevin misterpoopoohead@ ... wrote:
> > > From: Kevin misterpoopoohead@ ...
> > > Subject: [2cylinderhondas] New tires are wearing out fast!
> > > Hi Gang,
> > > I put new tires on my car less than 1000 miles ago and they are > > already > > > noticably worn in the front. The front end may not be perfectly > > aligned > > > but I wouldn't expect the tires to get worn out in so few miles.
> > > I bought the Kumho 145/8010's. These are T rated tires. They ride > > nice > > > but they are not going to last to long.
> > > kev
