Re: [2cylinderhondas] Re: speedometer no longer accurate
Miles;
    That's interesting, but I read it differently.  The bias ply tires did two things, gave a softer ride and at speed caused the tire to squeez so that less tire tread was meeting the pavement.  So the tire at 50 mph was really taller than the radial which flatens out more keeping more tire on the road, better handling.  I have some NanKing tires from China that are bias nylon tires, they will try and run the grooves CALTRANS put in the freeways to keep the cars from hydroplaning when it rains.   Just the worst tires I have ever put on a car.  But I still have them with a set of "Port-a-wall's" installed, nice touch at shows.
> Friday, June 20, 2008 9:22
> In one of the road tests for the Honda 600 Sedan it claims speedo
> innacuracy by 5 or 6 mph. The other thing is and I have mentioned > this > before is; the early AN600 came with 5.20 x 10 bias ply tires > and a non > synchro trans. The later sedans had 145SR 10 Radials which > are slightly > shorter, mismatching these items will change your speed.
> The old myth
> of rolling the speedo backwards does not work is
> incorrect. It may not
> have worked on Ferris Buehlers Day Off's
> Ferrari, but it does work on a
> Honda 600, I've tried it!
> goinhm@... wrote:
> > In my earlier msg, I mentioned the
> speedo cable makes a 90 degree
> bend by
> > the master cylinder. That
> was incorrect. The speedo cable comes
> out of the
> > firewall on the
> right side and goes directly to the speedometer
> gear.
> When you disconnect the speedometer cable, you should be able to > turn the
> > cable and it should turn smoothly and not stick. You could attach
> a variable
> > speed drill to the cable and turn it slowly and
> observe the reading
> on the
> > speedometer.
> > Although you may have a bad speedometer, the "jerky"
> readings
> while
> > underway can be caused by the speedo cable needing
> lubrication.
> You can disconnect
> > it at the engine (next to
> dipstick), pull out the cable,
> lubricate it, and
> > slide it back
> into the sleeve. Check the cable where it goes from
> the
> > firewall
> to the engine/tranny and see if the cable sheath has any > damage or sharp
> > bends. Near the master cylinder is a spot where it takes a 90
> degree bend
> > and the cable or the sheath could be damaged at that
> spot.
> > When you pull out the cable, inspect it to see if it is
> frayed.
> If so,
> > you need a new cable.
> > good
> luck,
> > Dale
> > I've been driving the coupe to work every
> day (2mi roundtrip) for a
> > couple months. As of yesterday, the
> speedometer stopped displaying
> my
> > real speed. The speedo displays
> 10-15 now when I'm going 25-35, and
> > is much more 'jerky' when moving.
> The tachometer is fine, and other
> > electrical connections seem fine
> (headlights, tail lights, interior
> > lights, etc).
> > Any
> ideas?
> > ************ **Gas prices getting you down?
> Search AOL Autos for
> > fuel-efficient used cars. (
> http://autos. aol.com/used?
> ncid=aolaut00050000 000007)
