Instrument removal
geez_tech
Instrument removal
Post by geez_tech »
I am trying to sort out some dash electrical issues on my N600 and it
may be easier if I can get the panel out. My manual says to remove
three screws then lift the panel out from the bottom then slide a lever
over, does this sound right?
I "think" I have found the screws but they look like a real pain to get
at, especially the one by the speedo, anyone else done this and maybe
have some suggestions?
Mike
Re: Instrument removal
Hi Mike;
I think your making to much of a project out of this.
Your electrical problems can't be that hard that the dash has to be removed.  The instrument panel can be removed with 80% if the wires right there.  Remove the radio and you have lots of room.  You have to do these things anyway.  Unless rats made a meal of your wires, I think you would have a much better chance of correcting your problem with all the wiring in place.
> geez_tech
> Thursday, July 31, 2008 9:57 PM
> [anzhonda600owners]
> Instrument removal
> have some
> suggestions?
> Mike
geez_tech
Post by geez_tech »
Yes, that is what I asked about, the panel and not the dash board.
I have the radio out and I can see in behind the speedo, but I need
to get at the cluster with the fuel gauge in it this is a little more
difficult to get at and if I could pull the panel out some then this
would make it easier to get at.
I'm having hard time finding the screws for the panel.
Mike
, wrote:
> Hi Mike;
> I think your making to much of a project out of this. Your
electrical
instrument
radio
Unless rats
chance of
]On Behalf Of geez_tech
> Sent: Thursday, July 31, 2008 9:57 PM
> Subject: [anzhonda600owners] Instrument removal
and it
lever
to get
maybe
> Mike
Mike,
    Would it help to be able to remove the speedometer gauge?   The speedometer can be removed by
holding on to the outer edge and pulling on it.  You could also disconnect the cable at the speedometer
and then push it out from inside the dash.  It isn't bolted in place and once removed will let you see the inside and figure out how to remove whatever else interests you.
    If does pull out but it may take a little wiggling to get it started.  Once out,  you will see the spring tabs along the edge which keep it from falling out while driving.
> Yes,
> I have the
> radio out and I can see in behind the speedo, but I need > to get at the > cluster with the fuel gauge in it this is a little more > difficult to get > at and if I could pull the panel out some then this > would make it easier > to get at.
> panel.
> Mike
Looking for a car that's sporty, fun and fits in your budget?
Read reviews on AOL Autos .
Mike and Tami Speer
Post by Mike and Tami Speer »
Yes, that may be enough for me to finish checking things, thanks for the tip Dale.
Mike
Mike;
The insturment gauge cluster and speedometer pop out without removing the panel.  Just make sure you watch not to bugger up the plastic.
> geez_tech
> Friday, August 01, 2008 12:50 PM
> [anzhonda600owners] Re:
> Instrument removal
> I
> have the radio out and I can see in behind the speedo, but I need > to get > at the cluster with the fuel gauge in it this is a little more > difficult > to get at and if I could pull the panel out some then this > would make it > easier to get at.
> panel.
> Mike
> > Hi Mike;
> > I think
> electrical
> instrument
> Remove the
> radio
> things anyway.
> Unless rats
> chance of
> ]On
> Behalf Of geez_tech
> > I am
> trying to sort out some dash electrical issues on my N600 > and it
> lever
> to get
> > at, especially
> maybe
> > have some
> suggestions?
> > Thanks,
> > Mike
mike;
    Go to www.honda600coupe. com  Steven Michelsen [stevenm@...]
 site which has all the books.  Your dash is in chapter 18 with electrical in chapter 17 of the Sedan Shop manual.  And, don't forget to look in the Coupe manual, it really is the suplement to the Sedan manual, containing all the up dated carb and later transmissions that were used by both the sedan and coupe.
   Steve has spent a great deal of time and effort to bring these items to you with little more than a click.
Even now after many years of woking on these small cars I refer to the shop manuals to refresh my memory.   The cost of printing this out for your own use is less than a ream of paper with your computer's printer you will have a working copy.
geez_tech
Post by geez_tech »
Thanks Bill,
I had been there before but didn't realize how much info he has
stored there, that is the perfect site for these cars, thank you to
Steven too for putting that much time into his site and making it
available to everyone.
His manuals explain why I am having trouble, I guess I have
the "deluxe" panel with the two seperate gauge pods, I was looking at
the instructions for the regular panel in my Haynes manual. Going
through Steve's manual I would have to remove the whole dash assembly
to get that panel out, there was the confusion with my post about
removing it.
Mike
, wrote:
> mike;
> Go to www.honda600coupe.com Steven Michelsen [stevenm@...]
electrical in
the Coupe
all the
sedan and
> coupe.
items to
> you with little more than a click. Even now after many years of
woking on
memory. The
paper with
]On Behalf Of Mike and
Tami Speer
> Sent: Friday, August 01, 2008 8:42 PM
> Subject: RE: [anzhonda600owners] Re: Instrument removal
for the
> tip Dale.
> Mike
] On Behalf Of goinhm@...
> Sent: Friday, August 01, 2008 8:27 PM
> Subject: Re: [anzhonda600owners] Re: Instrument removal
> Mike,
The
disconnect
place and
remove
started.
it from
> good luck,
board.
need
little more
this
> Mike
Read reviews
> on AOL Autos.
> Checked by AVG -
http://www.avg.com
> Version: 8.0.138 / Virus Database: 270.5.10/1585 - Release Date:
8/1/2008
> 6:39 AM
Hi Mike,
  In an earlier post you mentioned you were having electrical wiring problems.
I have found the two areas which seem to be the most likely culprit for wiring problems
in the dash to be (1) the connections at the fuse box, and (2) the ignition switch.  If the resistance
of either of these two items becomes too high,  the car experiences problems.  With the fuse box,
check that it is not becoming hot when you have all the accessories (engine on, headlights on, heater on)
are on.  You can also measure the voltage across each of the fuses at the connector clips.  If you are able to see a voltage,  you have a problem.  Also check for corrosion at the plating on the clips and where the wire lugs connect to the fuse box.  The ignition switch can also develop significant resistance which creates too much voltage drop.
Again, measure the voltage as it enters and leaves the switch.  If you see a voltage drop across the switch,  you have a problem.
> Thanks Bill,
> I had been there before but didn't realize how much info he > has > stored there, that is the perfect site for these cars, thank you to
> guess I have
> the "deluxe" panel with the two seperate gauge pods, I was > looking at > the instructions for the regular panel in my Haynes manual.
> Going
> through Steve's manual I would have to remove the whole dash > assembly > to get that panel out, there was the confusion with my post about
> removing it.
> Mike
> > mike;
> > Go to
> www.honda600coupe. com Steven Michelsen [stevenm@... ]
> > site
> which has all the books. Your dash is in chapter 18 with > electrical > in > > chapter 17 of the Sedan Shop manual. And, don't forget to look in
> the Coupe
> containing
> all the
> used by both the
> sedan and
> > coupe.
> > Steve has spent
> items to
> > you with
> woking on
> these small cars I refer to the shop manuals to refresh my > memory.
> The
> paper with
> copy.
> ]On
> Behalf Of Mike and
> Tami Speer
> > Yes, that may be enough for me to finish checking things, > thanks > for the > > tip Dale.
> > Mike
> > Mike,
> > Would it help to be
> The
> > speedometer can be
> removed by
> You could also
> disconnect
> place and
> how to
> remove
> started.
> which keep
> it from
> > good luck,
> > Dale
> > Yes, that
> board.
> > I have
> need
> > to
> little more
> this
> > Mike
> budget?
> Read reviews
> > on AOL Autos.
> > No virus found
> > Checked by AVG -
> http://www.avg. com
> > Version:
> 8/1/2008
> 6:39 AM
Mike;
    Also, look at the parts manuals, they carry the blow-up views of the cars and all the parts.  Really helps to see the internals before taking things apart.
> geez_tech
> Saturday, August 02, 2008 1:19 PM
> Instrument removal
> Thanks Bill,
> guess I have
> Going
> removing it.
> Mike
> > mike;
> > Go to
> > site
> the Coupe
> containing
> all the
> used by both the
> sedan and
> > coupe.
> > Steve has spent
> items to
> > you with
> woking on
> The
> paper with
> copy.
> ]On
> Behalf Of Mike and
> Tami Speer
> > Mike
> > Mike,
> > Would it help to be
> The
> > speedometer can be
> removed by
> You could also
> disconnect
> place and
> how to
> remove
> started.
> which keep
> it from
> > good luck,
> > Dale
> > Yes, that
> board.
> > I have
> need
> > to
> little more
> this
> > Mike
> budget?
> Read reviews
> > on AOL Autos.
> > No virus found
> > Checked by AVG -
> http://www.avg. com
> > Version: 8.0.138
> 8/1/2008
> > 6:39
