Ray Cave, the Eagle-et (sp) king of the world is correct. I have seen a few of them set up this way, but I will bet Ray has done the setting up. I always wondered if this would also be charging the battery at the same time?
Ray, any notes on this?
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > Ray Cave > Sent:
> Friday, September 05, 2008 6:51
> [2cylinderhondas] PO wiring
> Steve, it might be for tail-light wiring for pulling your Honda on > a tow bar behind
> an R.V. - it would be like wiring a small trailer for lights, > except it's not a trailer,
> it's a Honda - you might look under the front bumper and see if > there has been
> a tow bar attached in it's previous life - I think the Honda could > be towed w/all
> four wheels down. Ray
> --- On
> Fri, 9/5/08, Steven
> Michelsen
> > From: Steven
> > Michelsen
> > To: "Honda group - anzhonda600owners"
> > , "Honda group - > > 2cylinderhondas" > > > > Date: Friday, > > September 5, 2008, 8:41 AM
> > In the process of pulling the battery and
> > tray for my rectifier-cable- replacement project, I discovered some > > wiring that could only be done by some previous owner. I cannot > > tell what on earth this guy had in mind! It's a four-pin > > connector, the sort that's found on the rear bumper of one's car, to > > connect trailer lighting, with some slack and a cable that goes > > through the firewall, then traces inside the car along the side, where > > it is connected to a multi-wire strip heading for the back of the > > car. I have not yet traced it to the end.
> > See this picture
> > of the cable in the engine
> > bay. I have left it all intact for further investigation.
> > Anybody care to guess what this is all about?
> > Steve
