my turn signal isnt blinking, it stays solid. it will only blink if i put it to hazard...
i shaved off the turn signals on the car, so all i have is the back rear light as a turn signal.
turn signal not blinking
blake neilson
Re: turn signal not blinking
The total current flow through the flasher is cut in half with the removal of the fronts. The flasher needs both bulbs to be in operation in order to work properly. I would rewire the fronts even if you have to hide them to get the look (shaved) you want.
Wed, 9/16/09, tranng84
> From: tranng84
> Subject: [anzhonda600owners] turn signal not blinking
> Date: Wednesday, September 16, 2009, 4:10 PM
