Re: [2cylinderhondas] Fumes?
Bruce, Dale;
There are other things taking place in the fuel systems these days.  Alcohol 15% and more is causing lots of problems.  But the Vent hose (#6) in the parts manual picture, is the closest dog to the sled.
    The recombined fuels they are pumping into your tank can cause the vent tube to shrink, even crack.  If it is like mine, it's hard as a rock.  Shrink tube will melt, so will vinyl tubing.
Replacing the line will involve removing the tank.  Not all that fun but with a beer or two the job is more palatable.  Early Coupes are a real bear as the bolts can be troublesome.  Later units have the clips and make the job easier.  The tanks are interchangeable and after market clips are cheap.  Not that the carb couldn't be the culprit, but I can't remember smelling fuel from the carb while behind the wheel.
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > Bruce Dewing > Sent:
> Monday, March 29, 2010 9:19
> Good
> info Dale.
> As for interior gas fumes, take a look at the gas tank
> ventilation hose.  Take the pocket cubby out (plastic bit left side under > window, next to the gas pipe) and check to see if the plastic hoses are still > connected at the union.  If not, replacement hose, and perhaps some > shrink tubing to bind it together will seal it.  Do not use tape, the > fumes will dissolve the adhesive.
> A normal car will not have any
> fumes, gas or exhaust.  You need to fix this.
> Bruce D.
> Santa
> Clara, CA
> "goinhm@aol. com"
> Mon, March 29, 2010 1:16:29
> You should not be smelling gas inside the car (or even under the > hood).  You might try disconnecting the blue wire going to the > distributor (so you don't burn the points for this test),  remove the > air cleaner cover and the air filter,  and then turning the > ignition switch to the "ign" position.  This will let the fuel pump send > gas to the carb.  After the carb fuel bowl is full,  the clicking on > the fuel pump will scale back to about 1 click every 20 seconds or > longer.  If you hear it clicking more often (i.e. clicking at less than a > 5 second interval),  check for a fuel leak.  Look inside the air > cleaner housing  and see if gas is appearing.  You can also reach > into the carb bellows and feel for it (if you find it in this area,  the > needle and seat in the float bowl area are gunked up and will need > cleaning.... possibly replacing.  Before tearing into the carb, > check the fuel pump to see if it is a stock pump and check the > pressure.  My coupe shop manual specs the pressure at 2 > psi which seems low ...... I thought it was about 4 psi).   If this > is ok,  look for a leak along the fuel line (you may be able to see where > it is dripping).
> good luck,
> > Went
> > for a drive with the N600's new exhaust this weekend, and I was surprised > > how 'fumey' the car still was, even inside. Much better, but was still > > smelling strong gasoline smell inside the car.
> > Same thing with the
> > Z600, even after the new exhaust.
> > Is this normal when the cars are
> > running right?
> > I'm thinking that they are both running quite rich
> > perhaps? I need to pull the plugs and take a look. Probably do need to > > adjust the carb, but wanted to get some feedback > > first.
