Rotor/ flywheel removal tool readily available
paul tate
Post by paul tate »
After lots of time on the net and on the phone I finally found something that works well for a rotor/ flywheel removal tool. It is an oil drain plug for a 2004 Volkswagen Touareg (V8 only), $21.98 at the VW dealer. It isn't long enough but with the use of some grease and a 1/2" nyloc nut as a spacer it worked very well. Okie rigging at it's finest!
O yea, if you car happened to be one of the many missing an oil dran plug at Wal-Mart, SORRY, it took a while to find the right one.
roger white
Re: Rotor/ flywheel removal tool readily available
Post by roger white »
sorry to jump in on thread but I deleted the gentelmen looking for affordable
tail lights.
If you were looking for the marker/backup light assy. I have a drivers side assy for $35 plus shipping from Omaha to where ever. The metal is all straight.
Gasket in great shape. there are 2 problems with it. It has fine scratches on part of the chrome on top side. ( could be polished out)   It is missing the curved clear back up lens.  ( I have seen the repo lens here before)
paul tate To:
Tue, May 25, 2010 5:44:53 PM Subject:
[anzhonda600owners] Rotor/ flywheel removal tool readily available
