I purchased some a few years back. They don't always have them on the shelf. Like anything else, I had to wait for several weeks to get them in. I ordered through a machine shop where they had the cylinders bored 1.5 thousands over piston size and matched the rings.
As Miles said, the rings always come in a bit larger than spec. In fact the rings I ordered for my 67 Datsun pickup, had the next size up oil rings. If you are still in the "do it yourself" mode. Eastwood sells a ring grinding tool, works great.
> Friday, August 13, 2010 11:25
> [2cylinderhondas] Re: Available pistons for the N600
> Hastings sell piston rings but not all sizes. The part number is 2C9500 for > the standard size, then it is 2C9500 +.010 for the .25mm oversize and .020 for > the .50mm etc, but I am pretty sure they don't have any 40's > You can > get the 74mm civic piston rings in all sizes and have the oil ring groove > widened on the piston to 3mm, I have had it done a couple times. A machine > shop can do this. The problem with the Hastings rings is they don't come > fitted, you actually have to grind the ends to achieve .008" to .015" > clearance or your engine will seize if they are too tight.
> My 1993 Geo
> Metro 3 cylinder had the exact spec pistons - 74mm x 17mm pin exact location > of pin in piston but the tops were dished instead of domed.
> In all the
> years of my searching, I have never found a good match, you can have them made > but price is high.
> goinhm@... wrote:
> > It has been mentioned in the past
> on this group that Hastings sells pistons
> > for the Honda 600. I tried
> to look it up at _www.hastingsmfg.com_
> http://www.hastingsmfg.com
> ) but the site
> was not available tonight.
> > Dale
> > You are
> correct Tom ! Seem's as though they are not domed & height of
> piston face is less, bringing about lower compression. I am going to get hold
> > of one & make a direct comparison.
> _2cylinderhondas@yahoogroups.com
> _
> > (mailto:
> , "TOM THIES" wrote:
> Marshall
> > > seems to me that some one has check on that and there
> was something
> > about the top of the piston (not as much compression I
> think) but I may be
> > wrong so it is worth checking out.
> it would be great if they worked out for us.
> > > Tom
> T
