Hey there, I posted this on the other group but hadn't heard anything.
so I'll repeat myself:
After obtaining a bunch of parts from craigslist over the summer, I am trying to
piece together a complete engine. Even though there are some parts that I am
missing, I taking my time to clean up the parts that I do have. One of those
parts is an intact crankcase. It is next in line to clean by sandblasting, but
I wanted to check with the group to see if you can offer up suggestions on what
to be careful about since I haven't cracked one open before.
Pictures:
n600sedan.blogspot.com
Thanks everybody
Marty
San Francisco
Opening the crankcase - offer any caution??
juniselect
Re: Opening the crankcase - offer any caution??
Marty
I am sure some one here will help you on this. I have never taken mine apart but there is a lot of people here that can help you. They might just not be around right now.
Tom T
Tom T
> juniselect
> Monday, November 22, 2010 6:32
> [anzhonda600owners] Opening the
> Hey there, I posted this on the other group but hadn't heard > anything.
> piece together a
> complete engine. Even though there are some parts that I am > missing, I > taking my time to clean up the parts that I do have. One of those > parts is > an intact crankcase. It is next in line to clean by sandblasting, but > I > wanted to check with the group to see if you can offer up suggestions on > what > to be careful about since I haven't cracked one open > before.
> Pictures:
> Thanks
> everybody
> Marty
> San Francisco
blake neilson
Although I haven't done it in over 30 years taking it apart should be fairly straightforward. I don't recall it being problematic.
The reason for my reply is regarding your plan to sandblast or beadblast the case. I would advise against it. In my experience it is very difficult to get all of the sand or glass beads out of all the nooks and crannies of the casting. Any remaining material is at risk of being picked up by your oil pump. True it should then be captured by the oil filter but the oil pump it not protected. The oil pumps on these engines are marginal and don't need to be compromised. Just my two cents.
Blake
Blake
Mon, 11/22/10, TOM THIES
> TOM THIES
> Subject: Re: [anzhonda600owners] Opening the crankcase - offer any caution??
> Date: Monday, November 22, 2010, 6:53 PM
> Marty
> I am sure some one here will help you on this. I have never taken > mine apart but there is a lot of people here that can help you. They > might just not be around right now.
> Tom T
> > juniselect
> > PM
> > Hey there, I posted this on the other group but hadn't heard > > anything.
> > piece together a
> > complete engine. Even though there are some parts that I am > > missing, I > > taking my time to clean up the parts that I do have. One of those > > parts is > > an intact crankcase. It is next in line to clean by sandblasting, but > > I > > wanted to check with the group to see if you can offer up suggestions on > > what > > to be careful about since I haven't cracked one open > > before.
> > Pictures:
> > Thanks
> > everybody
> > Marty
> > San Francisco
Herbert McCoy
Someone out there said an oil plug from a vw touareg with shims would work as a flywheel puller. What year must it be or are they all the same?
Herb From:
blake neilson To:
Tue, November 23, 2010 7:29:31 AM Subject:
Blake
Herb From:
blake neilson To:
Blake
> TOM THIES
> Marty
> Tom T
> > juniselect
> > PM
> > piece together a
> > Pictures:
> > Thanks
> > everybody
> > Marty
> > San Francisco
I looked into it and I am not exactly sure, but I think it would be any year touareg with the 4.2 V8. The size is 24mm x 1.5 Good luck.
Herbert McCoy To:
Wed, November 24, 2010 11:03:32 AM Subject:
Herb From:
blake neilson To:
Blake
Herbert McCoy To:
Herb From:
blake neilson To:
Blake
> TOM THIES
> Marty
> Tom T
> > juniselect
> > PM
> > piece together a
> > Pictures:
> > Thanks
> > everybody
> > Marty
> > San Francisco
Herbert McCoy
Thanks Herb From:
brad fenn To:
Wed, November 24, 2010 8:57:43 PM Subject:
Herbert McCoy To:
Herb From:
blake neilson To:
Blake
brad fenn To:
Herbert McCoy To:
Herb From:
blake neilson To:
Blake
> TOM THIES
> Marty
> Tom T
> > juniselect
> > PM
> > piece together a
> > Pictures:
> > Thanks
> > everybody
> > Marty
> > San Francisco
