Re: Pulley
Re: Pulley
To find the fan belt pulley bearing puller go to:
mygto_1999
Re: Pulley
Post by mygto_1999 »
Thanks Bill,     I have seen that at the site before but we are talking about the bearings in the cooling fan assembly itself, not the drive belt pulleys.
Mike
Re: Pulley
Hi Mike;
Ok, I thought some one was talking about the side fan pulley wheels.  Just a thought, and I have not had to redo these bearings for a very long time.  But with other bearings and bolts just stuck I found that "CRC Freeze-off" really works.  It's much like heating the shaft, but you can't get to the shaft and aluminum tends to do funny things with a torch applied.  But this Freeze-off stuff takes a different approach causing dissimilar metals to contract which allows them to be pulled apart.
    The last time I had a pulley taken off the fan assembly I took it to a machine shop and they had it off in a few minutes.
Then replacing the bearings was a snap.  Reassembly was not a problem, but I took care not to place any pressure on the plastic fan.  If you need numbers for the bearings I think I still have a set of them stored away, just have to dig them out.
Hope this helps.
> Mike & Tami
> Speer
> Saturday, March 31, 2012 1:51 PM
> RE: [anzhonda600owners]
> RE: Pulley
> Thanks
> Bill,
>     I have seen that at
> the site before but we are talking about the bearings in the cooling fan > assembly itself, not the drive belt pulleys.
> Mike
> billmyong@...
> Friday, March 30, 2012 11:52
> Mark Parrish;
> [anzhonda600owners] RE:
> Pulley
> To find the fan
Bob Bondiett
Re: Pulley
Post by Bob Bondiett »
Bill, my pulley bearings are making noise too and I would like to replace them soon. Yes, if you would be so kind to look up the bearing numbers- I would be forever in your debt!  Bob.
> "billmyong@..."
> Saturday, March 31, 2012 5:59 PM
> RE: [anzhonda600owners] RE: Pulley
> Hi
> Mike;
> pulley wheels.  Just a thought, and I have not had to redo these bearings > for a very long time.  But with other bearings and bolts just stuck I found > that "CRC Freeze-off" really works.  It's much like heating the shaft, but > you can't get to the shaft and aluminum tends to do funny things with a torch > applied.  But this Freeze-off stuff takes a different approach causing > dissimilar metals to contract which allows them to be pulled apart.
> Then replacing the bearings was a snap.  Reassembly was not a problem, but > I took care not to place any pressure on the plastic fan.  If you need > numbers for the bearings I think I still have a set of them stored away, just > have to dig them out.
> Hope
> this helps.
> > On Behalf Of
> > Mike & Tami
> > Speer
> > RE: Pulley
> > Thanks
> > Bill,
> >     I have seen that at
> > the site before but we are talking about the bearings in the cooling fan > > assembly itself, not the drive belt pulleys.
> > Mike
> > On Behalf Of
> > billmyong@...
> > PM
> > Mark Parrish;
> > Pulley
> > To find the fan
Re: Pulley
Hi Bob;
This is the number I have on file.
Cooling fan
bearing #6201RS .
However, before getting into the process of pulling (no pun intended) thins apart.  Try spraying some WD-40 on the belt.
These belts are known for making noises.  Also, if you can use a Mechanics-stethoscope, this is from JC Whitney, but Harbor Freight has them too.
http://www.jcwhitney.com/performance-to ... terid=u0j5
This way you can localize your diagnostics and listen to the bearing.  Some do go, many more are just a belt squeak.
> Bob
> Bondiett
> Saturday, March 31, 2012 3:58 PM
> Re: [anzhonda600owners]
> RE: Pulley
> Bill, my pulley bearings are making noise too and I would like to > replace them soon. Yes, if you would be so kind to look up the bearing > numbers- I would be forever in your debt!  Bob.
> > "billmyong@..."
> > Saturday, March 31,
> > 2012 5:59 PM
> > RE:
> > Hi Mike;
> > side fan pulley wheels.  Just a thought, and I have not had to redo > > these bearings for a very long time.  But with other bearings and bolts > > just stuck I found that "CRC Freeze-off" really works.  It's much like > > heating the shaft, but you can't get to the shaft and aluminum tends to do > > funny things with a torch applied.  But this Freeze-off stuff takes a > > different approach causing dissimilar metals to contract which allows them > > to be pulled apart.
> > off the fan assembly I took it to a machine shop and they had it off in a > > few minutes.  Then replacing the bearings was a snap.  Reassembly > > was not a problem, but I took care not to place any pressure on the plastic > > fan.  If you need numbers for the bearings I think I still have a set > > of them stored away, just have to dig them out.
> > Hope this helps.
> > > On Behalf Of
> > > Mike &
> > > Tami Speer
> > > Sent:
> > > RE:
> > > Thanks Bill,
> > >     I have seen
> > > that at the site before but we are talking about the bearings in the > > > cooling fan assembly itself, not the drive belt pulleys.
> > > Mike
> > > On Behalf Of
> > > billmyong@...
> > > Sent:
> > > PM
> > > Mark Parrish;
> > > [anzhonda600owners]
> > > RE: Pulley
> > > puller go to:
Bob Bondiett
Re: Pulley
I had the pulleys out some years back and found them to be devoid of grease. I pried off the race covers and added some but the bearings had already been damaged some and were a little rough. They have gotten worse this winter.  The fan bearing is as smooth as can be but the two pulleys are not. I had wondered how to get the bearings out until I saw the link to that homemade puller! Can do. Thanks.
> "billmyong@..."
> Saturday, March 31, 2012 7:00 PM
> Hi
> Bob;
> Cooling
> fan
> bearing #6201RS
> These belts are known for making noises.  Also, if you can use a > Mechanics-stethoscope, this is from JC Whitney, but Harbor Freight has them too.
> > On Behalf Of
> > Bob
> > Bondiett
> > RE: Pulley
> > Bill, my pulley bearings are making noise too and I would like to > > replace them soon. Yes, if you would be so kind to look up the bearing > > numbers- I would be forever in your debt!  Bob.
> > > "billmyong@..."
> > > Sent:
> > > Saturday, March 31,
> > > 2012 5:59 PM
> > > RE:
> > > Hi Mike;
> > > side fan pulley wheels.  Just a thought, and I have not had to redo > > > these bearings for a very long time.  But with other bearings and bolts > > > just stuck I found that "CRC Freeze-off" really works.  It's much like > > > heating the shaft, but you can't get to the shaft and aluminum tends to do > > > funny things with a torch applied.  But this Freeze-off stuff takes a > > > different approach causing dissimilar metals to contract which allows them > > > to be pulled apart.
> > > off the fan assembly I took it to a machine shop and they had it off in a > > > few minutes.  Then replacing the bearings was a snap.  Reassembly > > > was not a problem, but I took care not to place any pressure on the plastic > > > fan.  If you need numbers for the bearings I think I still have a set > > > of them stored away, just have to dig them out.
> > > Hope this helps.
> > > Bill
> > > > From:
> > > > On Behalf Of
> > > > Mike &
> > > > Tami Speer
> > > > Sent:
> > > > To:
> > > > Subject:
> > > > RE:
> > > > Thanks Bill,
> > > >     I have seen
> > > > that at the site before but we are talking about the bearings in the > > > > cooling fan assembly itself, not the drive belt pulleys.
> > > > Mike
> > > > From:
> > > > On Behalf Of
> > > > billmyong@...
> > > > Sent:
> > > > PM
> > > > To:
> > > > Mark Parrish;
> > > > Subject:
> > > > [anzhonda600owners]
> > > > RE: Pulley
> > > > puller go to:
