front brake hose replacement
robert martinez
So during the restoration process I found out that my brake lines were clogged ... so I went around looking for a place to make me some.. no luck .. they either didn't have the banjos or they didn't have enough.. + they wanted to charge me $50 per hose .. after trail and error and research I found out that the upper brake hose of a 89-90 Suzuki katana 750 are pretty much the same the only difference being that they are about 2" longer .... I think that is a small price to pay given that they set me back $13 a piece .. its up to u to use the info I'm giving you .. you can ignore this if you are not the type to use parts not intended for our hondas
Re: front brake hose replacement
Hi Robert;
Good info, everything helps. But as for the cam chain, use the heavy duty type. Like you said and we all have discovered that a racing application will be strong enough.
> robert
> martinez
> Wednesday, May 30, 2012 12:43 AM
> [anzhonda600owners] front
> So during the restoration process I found out that my brake lines were > clogged ... so I went around looking for a place to make me some.. no luck ..
> they either didn't have the banjos or they didn't have enough.. + they wanted > to charge me $50 per hose .. after trail and error and research I found out > that the upper brake hose of a 89-90 Suzuki katana 750 are pretty much the > same the only difference being that they are about 2" longer .... I think that > is a small price to pay given that they set me back $13 a piece .. its up to u > to use the info I'm giving you .. you can ignore this if you are not the type > to use parts not intended for our hondas
robert martinez
If any one is wants to know more about that brake hose go to
http://www.cheapcycleparts.com/model_ye ... brake-hose
It is ref# 4 part # is there
To be honest , I bought mine used and I have not installed it yet because I can't seem to remember where I left my calipers... but the banjo bolt fits perfectly.. I'll link a picture upon request of the hoses Side by side
