Fuel float gasket needed
eric.geiger
Post by eric.geiger »
Does anyone have a gasket for the fuel float in the gas tank?
part number 37811-605-150
it goes between the float and the tank.
im reinstalling my gas tank next week and need a gasket.
Thanks
Eric
Re: Fuel float gasket needed
Erick;
You can cut one out of any fuel resistant gasket material auto zone or NAPA …  has on the shelf.  Cars from the 50’s used paper ones all the time.  What ever you do, don’t us a silicone based sealer.  Or make-a-gasket stuff that is silicone based as it will plug up your pickup tube if any falls into the fuel tank when you screw it tightly in place.
Robert James
Post by Robert James »
Eric, will this part fit? �If so, maybe I should order one!
http://www.cmsnl.com/honda-n360-life_mo ... 811605150/
Bob
On Fri, May 10, 2013 at 10:02 PM, eric.geiger
> Thanks
> Eric
Post by Eric Geiger »
Yes it will.  I actually am going to end up using the same one.  I ordered one from there but it won't be delivered in time.  I found another member who has a NOS one that I'm gonna use then just ship them the one I ordered.
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX phone
XXX-XXX-XXXX fax
XXX-XXX-XXXX mobile
egeiger@...
www.prgnocturne.com
On May 11, 2013, at 9:25 AM, "Robert James" wrote:
Eric, will this part fit?  If so, maybe I should order one!
Bob
> Thanks
> Eric
