Honda 600 melt down
Mark P Hatten
Honda 600 melt down
Post by Mark P Hatten »
My N600 melts down. I don't quite understand it all yet. I replaced the alternator brushes and thought I had repaired the charging system. A couple of days go by, I get in to drive home from work and "???!". I need to vent and cool off.
http://www.youtube.com/watch?v=lPVM-0BzRsg
Mark Portland Or.
www.mphspecialties.com
Re: Honda 600 melt down
Post by Eric Geiger »
mark i made a batch of replacement battery cables with the proper body grounds.  just like original honda ones.  if you want one contact me for good guy pricing
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX  phone
XXX-XXX-XXXX  fax
XXX-XXX-XXXX  mobile
egeiger@...
www.prgnocturne.com
> Mark
> Portland Or.
Kurt
Front spring lowering help
Post by Kurt »
I remember a while back some one cut the front springs to lower the front just a bit. How much was cut out?? Just so I don't have to do it two or three times.
 Kurt
Mark
Portland Or.
Re: Front spring lowering help
There's a guy that makes coil overs as well.   They're not cheap but he fully rebuilds it all so it should last for the life of the car.   Turn around time is kinda long so might be best buying a set from someone or if u have spares sending those instead.
Email me if u want his info.
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX phone
XXX-XXX-XXXX fax
XXX-XXX-XXXX mobile
egeiger@...
www.prgnocturne.com
Kurt
> Mark
> Portland Or.
Kurt
Post by Kurt »
Mark
Thanks for the heads up on cutting the springs
3 good,
5 nice n low,
6 to much
Thanks again  Kurt
Kurt
> Mark
> Portland Or.
Chas
Post by Chas »
Hi Mark,
This is classic. If the engine has a bad grund cable, the engine will try to ground itself through the metal cables, which causes extreme heat and meltdown. Replace the intended ground and lose the unintended ones!
Chas
> Mark
> Portland Or.
richmccolman
Post by richmccolman »
Chas is right. There's a reason why a car needs to be grounded from the battery to BOTH the engine AND the body/chassis. You can't count on having a solid ground between the battery and the body without a separate battery-to-body ground cable.
If the engine were solidly mounted metal-to-metal to the chassis/body, a separate battery-to-body grounding cable wouldn't be necessary. However, remember that great care is taken to mechanically dampen the engine-to-chassis mounting points, using rubber or urethane, in order to reduce engine vibrations from getting transmitted into the chassis and body. Both rubber and urethane are electrical insulators as well, and serve to isolate the engine from the body, electrically. If only the engine is grounded to the battery, that means that all of the other non-engine-mounted electrical devices in the car have to derive one side of their circuits (the ground) through any (limited) engine-to-body/chassis metallic connections. Other than perhaps the shift linkage, the other metallic parts that might make significant electrically-conductive connections between engine and body/chassis would be stuff like the clutch or tach cables. Since the conductive connections through those pathways is nothing close to that of a solid battery-to-body ground cable, it's not at all weird that you'd end up with a prime electrical pathway through each of those cables and have them heat up as a result. Although you might be able to get by running some light electrical loads in this configuration, turning on things like headlights or the blower motor, or worse -- multiple devices, can start to heat things up quite a lot since those parts are pretty flimsy compared with a big battery-to-body ground cable. If you try to pull too much electrical current though an inadequate electrical pathway, you get a lot of resistance to the electron flow and the result is HEAT, similarly to trying running a 1500-watt hair dryer through a small 22-gauge wire.
Hopefully those parts you identified in the video are the only casualties. However, it might be prudent to also look over the other wiring in the car to make sure that you don't have some cables with melted or burnt insulation.
Good luck,
Richard
, "Chas" wrote:
> Hi Mark,
> Chas
> > Mark
> > Portland Or.
richmccolman
Actually as I think about it some more, I suspect that the rest of the car wiring should probably be okay. Just add a battery ground to the body (along with the mechanical cables that got toasted) and you should be alright, I think. It's probably worth verifying that components like the voltage regulator didn't get damaged by the incident.
Richard
> Good luck,
> Richard
, "Chas" wrote:
> > Hi Mark,
> > Chas
> > > Mark
> > > Portland Or.
Mark P Hatten
Honda 600 melt down
Thanks for all your responses fellas. Yes I do believe it's a body ground issue.  I'd forgotten, that about a month ago or more I repaired a sagging rear motor mount. The metal innards of the mount was resting on in the metal outer parts, causing the engine to sag and gear shift to hang low through the fire wall hole. I raised and filled the mount with new rubber. Effectively insulating  the engine from the body.  Then after replacing the brushes and getting the charge system working created the perfect storm melt down. All the cables are being rebuilt. Speedo, clutch, and throttle. One dash light wire melted and some charging wires also got melted. I'll be putting engine to body ground straps on every thing I own from now on.
Mark Portland Or.
Richard
> Good luck,
> Richard
, "Chas" wrote:
> > Hi Mark,
> > Chas
> > > Mark
> > > Portland Or.
richmccolman
Sounds like you've got a handle on things now, Mark.
Hmm... I guess that my initial concerns (about the possibility of melted wires) was more on the mark than my rethink.
Good luck getting everything put back together!
Richard
> Mark
> Portland Or.
> Richard
> > Good luck,
> > Richard
, "Chas" wrote:
> > > Hi Mark,
> > > Chas
> > > > Mark
> > > > Portland Or.
