Mark;
Check the ground wire to the voltage regulator. You said your wires had melted insulation, the black wire to the voltage regulator often heats up and shorts to another wire or melts the wire to the point there is no connection. Pull the regulator off the car and look at the bottom of it and the plastic connector.
