Re: [2cylinderhondas] Re: AZ600 for sale
When you judge in a competitive showing, everything is assumed good/correct unless otherwise noted. So only the incorrect, missing and poor preservation items are listed. This is not to say that there are not good things about the vehicle being judged only that there is not sufficient room to list both. The exception will be that everything is well preserved or restored in which case this is noted. Take perspective in the notes and use them to make things better. If you are satisfied with the results then any comment shouldn't matter.
