N600 sedan - rear engine mount
Greg Prentice
Post by Greg Prentice »
Dropped the engine and subframe assembly yesterday and found the rear engine mount completely torn. It appears this is not uncommon.
Does anyone rebuild these with new rubber? Or does anyone have one with ‘ok’ rubber?
Thanks.
Greg Prentice
Toromont Power Systems
XXX-XXX-XXXX
XXX-XXX-XXXX.
Gary Prince
Re: N600 sedan - rear engine mount
Post by Gary Prince »
Tim Mings had NOS rear motor mounts 3 or 4 years ago when I needed one.
On Nov 30, 2015 10:18 AM, "Greg Prentice
GPrentice@...
> Does anyone rebuild these with new rubber? Or does anyone have one with ok rubber?
> Thanks.
> Greg Prentice
> XXX-XXX-XXXX
> confidential or legally privileged. If you are not the intended recipient you > are notified that disclosing, copying, distributing or taking any action in > reliance on the contents of this information is strictly prohibited. Please > notify us immediately by email at > corpmail@...
> �or by
> telephone (collect if necessary). Please delete this email and destroy any > copies. Thank you for your cooperation.
> www.toromont.com
> XXX-XXX-XXXX
> joints, sont consid�r�s comme confidentiels ou juridiquement privil�gi�s. Si > vous n'�tes pas le destinataire d�sign� du pr�sent message, soyez avis� que > toute divulgation, copie, distribution ou action se fondant sur le contenu est > strictement interdite. Veuillez nous en aviser imm�diatement par courriel � > l'adresse > corpmail@...
> ou
> par t�l�phone (� frais vir�s si n�cessaire). Veuillez effacer ce courriel et > toute copie �ventuelle. Merci pour votre coop�ration.� > Toromont > Industries Ltd., 3131 Highway 7 West, Concord, ON, L4K 1B7 > www.toromont.com
> XXX-XXX-XXXX
Greg;
Yes, I can recast your old mount. See attached.
_____
Greg Prentice
Thanks Bill.
I just got off the phone with Ming and he suggested the same thing using silicone.
I will try it myself but if I mess it up I might ask for your services.
Thanks again..
David Brower
Post by David Brower »
DANG , I JUST HAD A LOT OF 600 PARTS INCLUDING A GOOD REAR MOUNT ON E-BAY .
THEY WERE LISTED FOR ONE CENT , RAN FOR 10 DAYS AND NO ONE EVEN BID A SINGLE CENT .
HONDA N Z 600 COUPE PARTS LOT . FAN , FAN SHROUDS , PULLEYS , REAR MOTOR MOUNT
HONDA N Z 600 COUPE PARTS LOT . FAN , FAN SHR...
HONDA N Z 600 COUPE PARTS LOT . FAN , FAN SHROUDS , PULLEYS , REAR MOTOR MOUNT in eBay Motors, Parts & Accessories, Car & Truck Parts, Cooling...
View on www.ebay.com Preview by Yahoo
On Monday, November 30, 2015 1:42 PM, "Greg Prentice GPrentice@... [anzhonda600owners]" wrote:
Thanks Bill.
Thanks again..
Chad Spann
Post by Chad Spann »
Your shipping seemed high but I did not look at 600 parts this week. I usually do. Relist them and I will take a look. I am always stocking up on parts for Ns and Zs
David Brower the_rimspoke@... [anzhonda600owners] Sent:
11/30/2015 6:55 PM To:
anzhonda600owners@yahoogroups.com Subject:
Re: [anzhonda600owners] N600 sedan - rear engine mount
Thanks Bill.
Thanks again..
Note: 2 image(s) originally linked in this post are no longer available (ec, ec).
Hi Greg;
Yes, RTV coming out of the tube is an alternative but you know how well that
stuff sticks and your not doing anything to promote adhesion or to catalyze
the RTV going into the mount housing. RTV doesn't create heat, so if the
original rubber is failing at the ends then squirting an adhesive (which is
what RTV is) around it doesn't last. I found that placing a strip of 1/4
in. rubber on top of the Tung and below it with the RTV helped to add
strength to the RTV as it had something hard to take the jarring effects of
the engine. Here too, the RTV had to be replaced after a while because it
wasn't strong enough to keep the metal Tung on the Rear Engine mount from
slowly pushing the rubber out. Figure RTV has the hardness of a rubber
band. The product I use has the hardness of a rubber shoe heel. It has
some give, but not like a rubber band.
_____
Chad, your rear engine mount is for a Coupe, he was looking for a rear engine mount for a Sedan.
Chad Spann
Relist and I will bid. Thanx
Thanks Bill.
Thanks again..
Greg Prentice
Re: N600 sedan - rear engine mount [1 Attachment]
Good idea Bill !
Thanks.
