Brake sytem
ericksonj0705
Brake sytem
Post by ericksonj0705 »
Hey, out there, From Johnston, Iowa. I have a question. Has anyone changed the breaking system in a 600 away from the original Booster system? And had some success?  JoshATC
J Graf
Re: Brake sytem
Post by J Graf »
I have deleted the brake booster on one of my cars. Takes a little more brake pedal pressure, but it stops just fine.
> On Mar 23, 2016, at 1:19 PM,
> ericksonj0705@...
> [anzhonda600owners] anzhonda600owners@yahoogroups.com
Joshua Erickson
Re: Brake sytem
Post by Joshua Erickson »
Thanks, was thinking about trying that. Joshatc
On Wednesday, March 23, 2016 2:56 PM, "J Graf jgraf@... [anzhonda600owners]" wrote:
> ericksonj0705@...
J Graf
Re: Brake sytem
Post by J Graf »
Someplace, a number of years ago, I remember seeing a mod replacing the master cylinder with one from another vehicle, like a VW maybe. I dont remember if it was a post on one of the two Honda 600 boards with photos, or if it was a Youtube video. As I recall, the larger master cylinder effectively stopped the car as if the brake booster was still present. Perhaps someone else here remembers and can point you to it.
> On Mar 27, 2016, at 9:07 AM, Joshua Erickson
> ericksonj0705@...
> jgraf@...
J Graf
Re: Brake sytem
Post by J Graf »
OK, did a little research and discovered I was wrong sort of. The master cylinder swap I was remembering was not from a VW, but rather from a 1983 Honda. To find it, in either of the two Honda 600 groups, search the conversations for:
83 honda master cylinder
and it leads you to a link the documents what one Honda 600 owner did. Here is that link:
http://n600sedan.blogspot.com/2013/06/n600- master - cylinder -swap-for- 83 - honda .html
Joshua Erickson
Re: Brake sytem
sounds good, would like to hear more if someone remembers that. Thanks again.
On Monday, March 28, 2016 7:24 PM, "J Graf jgraf@... [anzhonda600owners]" wrote:
83 honda master cylinder and it leads you to a link the documents what one Honda 600 owner did. Here is that link:
Steering rack pinion bushings
A while back I posted a tutorial on rebuilding your steering rack.  Main problem with most steering racks is that the pinion shaft bushings vulcanized rubber seem to liquefy because of the grease used in this unit.  Attached are pictures of NOS bushings still in their sealed packaging.
When I opened the package I found that the rubber vulcanized to the bushing had already started to deteriorate.
As seen here it is sticking to the clear side of the wrapper.
Taking it out it stuck to my fingers and was not hard (as others I have used in the past).
Which leads me to believe the product used for this rubber has a useful life, and will go back to it’s liquid state over time.
So if you’re thinking of rebuilding the rack on your car, use Miles or Lyle's replacement bushings for the pinion shaft bushings.
Greg Prentice
Re: Steering rack pinion bushings [2 Attachments]
Post by Greg Prentice »
Thanks Bill.
I ordered bushings from CMS and the rubber was almost liquid –and they still in sealed package.
Can you provide Miles and Lyle’s contact info as I need to order new ones….
Thanks.
Miles e-mail is 600miles600@...
Lyle's e-mail is lyletrudell@...
Miles seem to just slip in, Lyle made his to fit over the metal bushing.  Both work.
Lyle Trudell
Post by Lyle Trudell »
Hi Bill, hope all is well. This is my Email: craft59@...
