Check the idle cutoff solenoid it sold click when you turn the key to on.
Sent from my Verizon 4G LTE smartphone
From: "'Bill Cockayne' bicockay1@... [anzhonda600owners]"
Date: 3/10/18 7:33 AM (GMT-05:00)
Subject: Re: [anzhonda600owners] My 1972 n 600 turns on by wont stay on!!! Help
Sounds like 2 problems. Even if charging circuit is not working vehicle still should not die when the choke is let off. Make sure battery is full charged, fuel solenoid clicks when given power, and then find out why it won`t idle. Plugged idle circuit in carb, vacuum leak, timing, valve adjustment all come to mind. Once it idles fine then you can troubleshoot the charging issue.
Wiring connections, grounds especially, are problematic on all older cars.
Voltage regulators can be bypassed momentarily to full field the alternator seeing if it even puts out. Any more questions ask. I owned one of these in the late 70`s and no one else would even touch it. Just bought me another!
mailto:anzhonda600owners@yahoogroups.com
Friday, March 09, 2018 11:11 PM
The 72 600 will turn over easy but afterbibgetvher warmed up and let off the choke she dies and the discharge light goes off. Ive bought a new regulator and rectifier and replaced those with no avail now I bought the brushes for the generator and if that doesnt work its the stator or the generator Can any one help me trouble shoot? Or are there any mechanics in the San Fernando valley i dont mind paying.... please XXX-XXX-XXXX!!!
Re: [anzhonda600owners] My 1972 n 600 turns on by won’t stay on!!!
Ellias Nassif
i fixed the idle problem now she's burning oil out of the pipe i put 10w 30 castrol my buddy said to put motor cycle oil what do you guys think
On Sat, Mar 10, 2018 at 9:51 AM, heedo
heedo@...
[anzhonda600owners]
> Check the idle cutoff solenoid it sold click when you turn the key to on.� > Sent from my Verizon 4G LTE smartphone > -------- Original message -------- > From: "'Bill Cockayne' > bicockay1@...
> [anzhonda600owners]" anzhonda600owners@ yahoogroups.com
> anzhonda600owners@yahoogroups. com
> Sounds like 2 problems. Even if charging circuit is not working vehicle > still should not die when the choke is let off. Make sure battery is full > charged, fuel solenoid clicks when given power, and then find out why it won`t > idle. Plugged idle circuit in carb, vacuum leak, timing, valve adjustment all > come to mind. Once it idles fine then you can troubleshoot the charging issue.
> Voltage regulators can be bypassed momentarily to full field the alternator > seeing if it even puts out. Any� more questions ask. I owned one of these > in the late 70`s and no one else would even touch it. Just bought me > another!
> mailto:anzhonda600owners@ yahoogroups.com
> on!!! Help
> The 72 600 will turn over easy but afterbibgetvher warmed up and let off the > choke she dies and the discharge light goes off. Ive bought a new regulator and > rectifier and replaced those with no avail now I bought the brushes for the > generator and if that doesnt work its the stator or the generator Can any one > help me trouble shoot? Or are there any mechanics in the San Fernando valley i > dont mind paying.... please > XXX-XXX-XXXX > !!!
What was the idle fix?
If it's burning oil and blowing smoke, there's only one way to fix it properly. Thicker oil may help. Motorcycle specific oil will make no difference.
Ellias Nassif
and how would you properly fix it?
On Sat, Mar 10, 2018 at 9:39 PM,
fredz@...
[anzhonda600owners]
> What was the idle fix?�
> If it's burning oil and blowing smoke, there's only one way to fix it properly.� Thicker oil may help.� Motorcycle specific oil will make no difference.
new piston rings as a minimum I'd suggest.
RE: [anzhonda600owners] My 1972 n 600 turns on by won't stay on!!!
The rings and valves can be checked with a simple compression test. When you do the test try and have the engine warm with both spark plugs removed and the throttle open. If you don’t have a compression test tool they are available from parts stores like Auto Zone.
Remove the Anti Dieseling Solenoid and look to see if the pin retracts with the ignition on and see if the O-ring is still good. Both can cause problems.
