Manifold Gasket?
Linda Classon
Manifold Gasket?
Post by Linda Classon »
Took my 71 Sedan to my local Honda dealer for a tune-up because it was
running rough. The diagnosis is that it has a bad manifold gasket and
there's gunk in the carburetor.
Does anyone have or know where to get the manifold gasket? I don't
care that it's authentic, just something that works. Also, does anyone
do carburetor re-builds?
Thanks!
Linda in CT
JGraf
Re: Manifold Gasket?
Post by JGraf »
I believe the manifold "gasket" is just an o-ring. I'm not sure about the size, so take the old one with. Most any hardware store should have one.
Thu, 5/27/10, Linda Classon
> From: Linda Classon
> Subject: [2cylinderhondas] Manifold Gasket?
> Date: Thursday, May 27, 2010, 2:53 PM
> Thanks!
> Linda in CT
As someone else noted,  the manifold "gasket" is just an o-ring.
If you can't find the correct
sized o-ring,  you can buy one which is slightly larger, cut it, and fit it to size. When you cut it,
do a 45 degree cut so it seals better (don't use a straight (90 degree) cut).
You can also use Permatex (or similar) sealer where the o-ring goes.
Also,  the clamp which holds the carb to the intake manifold needs to be tightened to seal the carb properly.  I have noticed the "rubber" which the intake is made of becomes hard with age and the carb may not be sealed properly which gives the same problem as a bad o-ring on the intake.
Your carb probably does not need to be rebuilt as much as it needs to be cleaned.  Removing the float bowl
gives access to everything and allows it to be cleaned.  You can use a spray can of carb cleaner to perform this task.   It is also a good time to verify the needle and seat are sealing properly.  You can do this by connecting a hose to the fuel intake line,  blowing into it and lifting the float up and down to see if it shuts off properly.  This is also a good time to check the float level which is an easy adjustment (you are just bending a metal tang).  Let us know if you have any questions.
> Took
> my 71 Sedan to my local Honda dealer for a tune-up because it was > running > rough. The diagnosis is that it has a bad manifold gasket and > there's gunk > in the carburetor.
> gasket? I don't
> care that it's authentic, just something that works. Also, > does anyone > do carburetor re-builds?
Ken,  Linda and other restorers of the Honda 600;
    Caution, the "O" ring is thinner tan the casual "O" ring supplied at the local hard ware store.
1 - It is thinner, to use one that is to thick will crack the base of the intake manifold when you tighten it down.  Or two thin and it does not seal.
2 - It must be resilient to fuels, Viton is best but Nitrile or Buna-N will work just as well.  Neoprene, Butyl or Natural Rubber will all fail.  Which can cause a fuel leak and besides catching on fire, there is short term fuel mileage loss and erratic carburetor function.
3 -  The person I was getting them from has retired so I have no idea of availability.   Also, the invoice noted special shipping and that was back in 2005.
If you can't find them, let me know and I will get in touch with them on Tuesday.
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > Kenneth Sievert > Sent:
> Thursday, May 27, 2010 3:10
> not sure about the size, so take the old one with. Most any hardware > store should have one.
> --- On
> > Linda Classon
> > 2010, 2:53 PM
> > Took my 71 Sedan to my local Honda dealer for a tune-up because it > > was > > running rough. The diagnosis is that it has a bad manifold > > gasket and > > there's gunk in the carburetor.
> > Does anyone have
> > or know where to get the manifold gasket? I don't > > care that it's > > authentic, just something that works. Also, does anyone > > do > > carburetor re-builds?
> > Thanks!
> > Linda in
> > CT
bottom cop
Post by bottom cop »
Surely by now, someone has an EXACT size of this o-ring.
Sat, 5/29/10, billmyong@...
> From: billmyong@...
> Subject: RE: [2cylinderhondas] Manifold Gasket?
> To: happy-accidents@..., krsievert@...
> Cc: "Anzhonda600owners" , 2cylinderhondas@yahoogroups.com > Date: Saturday, May 29, 2010, 4:22 AM
> > 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > > On Behalf Of > > Kenneth Sievert > > Sent:
> > Thursday, May 27, 2010 3:10 PM
> > Re: [2cylinderhondas] Manifold Gasket?
> > --- On
> > > From: Linda Classon
> > > To: 2cylinderhondas@ yahoogroups. com
> > > Took my 71 Sedan to my local Honda dealer for a tune-up because it was > > > running rough. The diagnosis is that it has a bad manifold gasket and > > > there's gunk in the carburetor.
> > > Does anyone have or know where to get the manifold gasket? I don't > > > care that it's authentic, just something that works. Also, does anyone > > > do carburetor re-builds?
> > > Thanks!
> > > Linda in CT
Post by feltonminicycle »
Honda still has these o rings in stock under a later model part number. I order them all the time. Will dig up the number later today.
The exact dimension is in the coupe parts book: 2.4mm x 42mm
> --- On Sat, 5/29/10, billmyong@... wrote:
> From: billmyong@...
[mailto:
]On Behalf Of Kenneth Sievert
> Sent: Thursday, May 27, 2010 3:10 PM
> Subject: Re: [2cylinderhondas] Manifold Gasket?
> --- On Thu, 5/27/10, Linda Classon wrote:
> From: Linda Classon
> Thanks!
> Linda in CT
Linda Classon
Thanks for everyone's help!
Now, all of a sudden she's not getting any juice from the battery
(fully charged). Started & ran (a bit rough) yesterday and today
absolutely nothing! Very frustrating.
Linda
bottom cop
The part number would be very helpful.  Thanks Miles
Sat, 5/29/10, feltonminicycle
> From: feltonminicycle
> Subject: [2cylinderhondas] Re: Manifold Gasket?
> Date: Saturday, May 29, 2010, 11:25 AM
> The exact dimension is in the coupe parts book: 2.4mm x 42mm > Miles > --- In > 2cylinderhondas@yahoogroups.com > , bottom cop wrote:
> > From: billmyong@...
> > Cc: "Anzhonda600owners" anzhonda600owners@yahoogroups.com
> > Ken, � Linda and other restorers of the Honda 600;
> > � � �  Caution, the "O" ring is thinner tan the casual "O" ring supplied at the local hard ware store.� > > 1 - It is thinner, to use one that is to thick� will crack the base of the intake manifold when you tighten it down.�  Or two thin and it does not seal.
> > 2 - It must� be resilient to fuels, Viton is best but Nitrile or Buna-N� will work just as well.�  Neoprene, Butyl or Natural Rubber will all > fail.� � Which� can cause a fuel leak and besides catching on fire, there is short term fuel mileage loss and erratic carburetor function.� � > > 3 -� � The person I was getting them from has retired so I have no idea of availability.� �  Also, the invoice noted special shipping and that was back in 2005.� � > > � > > If you can't find them, let me know and I will get in touch with them on Tuesday.
> > From: Linda Classon
> > Took my 71 Sedan to my local Honda dealer for a tune-up because it was > > running rough. The diagnosis is that it has a bad manifold gasket and > > there's gunk in the carburetor.
> > Does anyone have or know where to get the manifold gasket? I don't > > care that it's authentic, just something that works. Also, does anyone > > do carburetor re-builds?
> > Thanks!
> > Linda in CT
bruceb
Post by bruceb »
91325-568-000
O-RING (42X2.4)
Miles;
My original "O" ring measures at 2.6mm X 45.5mm and the manifold OD for the O ring is 49mm at the out side. Subtract the 2.6mm thickness of the O ring and your there.  The parts manual has some issues, like the part numbers for the rear brake cylinders and a number of the bolt lengths to name a few.
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > feltonminicycle > Sent:
> Saturday, May 29, 2010 8:26
> Honda still has these o rings in stock under a later model part number. I > order them all the time. Will dig up the number later today.
> The exact
> billmyong@...
> Manifold Gasket?
> > Cc:
> > Ken, � Linda
> � � �  Caution, the "O" ring is thinner tan the casual "O" ring > supplied at the local hard ware store.� > > 1 - It is thinner, to > use one that is to thick� will crack the base of the intake manifold when > you tighten it down.�  Or two thin and it does not seal.
> > 2 - It
> must� be resilient to fuels, Viton is best but Nitrile or > Buna-N� will work just as well.�  Neoprene, Butyl or Natural Rubber > will all fail.� � Which� can cause a fuel leak and besides > catching on fire, there is short term fuel mileage loss and erratic carburetor > function.� � > > 3 -� � The person I was getting them > from has retired so I have no idea of availability.� �  Also, the > invoice noted special shipping and that was back in > 2005.� � > > � > > If you can't find them, let me > know and I will get in touch with them on Tuesday.
> ]On
> "gasket" is just an o-ring. I'm not sure about the size, so take the old one > with. Most any hardware store should have one.
> > --- On Thu,
> > From: Linda Classon snet.net>
> > running rough. The
> > there's gunk in
> the carburetor.
> > Thanks!
> > Linda in CT
