Re: [2cylinderhondas] Re: Crankshaft question
Miles;
    I saw a couple of set-up's like this and they seemed to put a real draw on the engine, plus they used the fan belt and with that excluded the fan.  Looked like two strikes on the power plant for not much affect.  I have several use crank shafts and none show to have a magnetic crank anywhere but the stator shaft.  That doesn't mean that a magnetic field couldn't develop when the engine is running.  But then we would find metal chips around the seal on that end.  And, I have never found that to be true either.
    On the other hand, no fan and increased power draw on the end of the shaft seems like it would cause the engine to over heat.
Just my thoughts.
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > Steven Michelsen > Sent:
> Sunday, July 26, 2009 10:40
> Would a strategically placed magnet help keep
> down the loose steel bits?  On cars with screw-on filters one can use a > magnet that wraps around the filter.  Any way to emulate > that?
> Steve
> www.honda600coupe. com
> > Miles
> > Sunday, July 26, 2009 8:52
> > AM
> > Crankshaft question
> > That end will also attract steel particles and cause crank & rod life > > to be shortened. Though I have seen plenty of left crank rod failures as > > well. On a couple of my cars I put an external alternator from a Civic. It > > did 2 things, no magnetism on the crank and was so much easier to work on > > with no internal parts. Flywheel left intact for starting the car.
> > Miles
> > Tad Clark wrote:
> > > Yes, thats
> > normal. It's from the alternator being attached to one end of it.
> > > --- On Sat, 7/25/09, franknfike
> > > From: franknfike
> > > Subject: [2cylinderhondas] Crankshaft
> > question
> > Date: Saturday, July 25, 2009, 5:22 PM
> > > Is it normal for the crankshaft to be
> > magnetized?
Post by lyletrudell »
Pulled my cases apart.
Everything looked great, happy day!
Just like others have found, my crank shaft is magnetic on the flywheel side. From the alternator for sure.
It was stronger near the end away from the bearing.
I found no metal chips stuck to that area and the bearing looked good.
I will de-magnetize it and not worry about it.
, wrote:
> Miles;
> Just my thoughts.
]On Behalf Of Steven Michelsen
> Sent: Sunday, July 26, 2009 10:40 AM
> Subject: Re: [2cylinderhondas] Re: Crankshaft question
> Would a strategically placed magnet help keep down the loose steel bits?
> On cars with screw-on filters one can use a magnet that wraps around the
> filter. Any way to emulate that?
> Steve
> www.honda600coupe.com
> From: Miles
> Sent: Sunday, July 26, 2009 8:52 AM
> Subject: [2cylinderhondas] Re: Crankshaft question
> That end will also attract steel particles and cause crank & rod life to
> be shortened. Though I have seen plenty of left crank rod failures as well.
> On a couple of my cars I put an external alternator from a Civic. It did 2
> things, no magnetism on the crank and was so much easier to work on with no
, Tad Clark wrote:
> > Yes, thats normal. It's from the alternator being attached to one end
> of it.
> > --- On Sat, 7/25/09, franknfike wrote:
> > From: franknfike
> > Subject: [2cylinderhondas] Crankshaft question
> > Is it normal for the crankshaft to be magnetized?
