I saw a couple of set-up's like this and they seemed to put a real draw on the engine, plus they used the fan belt and with that excluded the fan. Looked like two strikes on the power plant for not much affect. I have several use crank shafts and none show to have a magnetic crank anywhere but the stator shaft. That doesn't mean that a magnetic field couldn't develop when the engine is running. But then we would find metal chips around the seal on that end. And, I have never found that to be true either.
On the other hand, no fan and increased power draw on the end of the shaft seems like it would cause the engine to over heat.
Just my thoughts.
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > Steven Michelsen > Sent:
> Sunday, July 26, 2009 10:40
> [2cylinderhondas] Re: Crankshaft question
> Would a strategically placed magnet help keep
> down the loose steel bits? On cars with screw-on filters one can use a > magnet that wraps around the filter. Any way to emulate > that?
> Steve
> www.honda600coupe. com
> > Miles
> > Sunday, July 26, 2009 8:52
> > AM
> > Crankshaft question
> > That end will also attract steel particles and cause crank & rod life > > to be shortened. Though I have seen plenty of left crank rod failures as > > well. On a couple of my cars I put an external alternator from a Civic. It > > did 2 things, no magnetism on the crank and was so much easier to work on > > with no internal parts. Flywheel left intact for starting the car.
> > Miles
> > Tad Clark wrote:
> > > Yes, thats
> > normal. It's from the alternator being attached to one end of it.
> > > --- On Sat, 7/25/09, franknfike
> > > From: franknfike
> > > Subject: [2cylinderhondas] Crankshaft
> > question
> > Date: Saturday, July 25, 2009, 5:22 PM
> > > Is it normal for the crankshaft to be
> > magnetized?
