$57-$64/shaft.
I think it's too much and I would need cores from everyone to get those prices.
I might just make myself a couple sets of new shafts when I get some free machine time. I could make the diameters a little larger to fit the slightly worn housing bores. Also increase the offset (.005") to get more adjustment. Of course heat treat them so they will last.
I think I could make them for $45/shaft.
, "lyletrudell" wrote:
> I bought 6.5mm lash caps to solve our valve adjustment issue, see lash caps post.
> Now I want to figure out how to repair the worn rocker shafts.
> My plan:
> *Have the large and small diameters ground (.005") undersize. In a cyclindrical grinder between centers.
> *Then chrome plate them (.006").
> *Then finish grind and buff them back to (+.0005") above stock size.
> I don't know of anyone with a cylindrical grinder.
> Any thoughts, been done before?
> Rocker arm shafts worn!
> Wow, fix one thing and find something else to fix!
> As you can see from my posts I am trying to rebuild my 600 engine to be as good or hopefully better than stock.
> I have worked on many engines over the years, don't claim to be an expert, I learn something new everytime I work on mechanical things.....Fun!
> By seeing lots of engines apart you can start to understand how all engines work, but they all have differences, poor designs and weak points.
> After seeing this engine apart and measuring everything, I would consider this engine a 50K mile motor at best, like a cheap motorcycle. Now add high RPM's, high temperatures and poor maintenance and we have an engine that won't last.
> Luckily we have other members who have dealt with these issues.
> I was reading past posts from Bill & Miles to learn about problem areas. Thanks guys!
> I have 8 rocker arm shafts from 2 engines and they are all worn on top. Both small and large diameters have about (.004"-.005") wear from the valve spring pressure pushing up on them.
> One good thing is that the cam housing bores are in great shape!Only (.001") wear max on the bores. Honda must have used a high silicon content in their aluminum, this makes it very hard. The problem with this type valve design is we run out of adjustment as the parts wear! (.002") wear on each part adds up fast!
> *Valve ends
> *Rocker arms
> *Cam shaft
> *Rocker shafts
> So I need to find NOS rocker shafts.
> I don't want to have to nickle/chrome plate my old ones oversize and then re-grind them back to size. Not a cheap thing to do.
> Why am I doing this?
