Can the Honda 600 handle?
Post by Lyle »
I will try and defend the honor of the Honda 600.
OK, Roman brought up some interesting points about how bad the Honda handles. Roman races and so do I, OK mines an enduro go-Kart and his is a high powered car. But, if I pick a tight twisty track with very little straight sections, I think my Go-kart with 4.5 in slicks up front with 6.5 rears will beat his race car. I am 1" off the ground, lay flat on my back and the kart with me in it weighs only 365 lb's. Even though he has a huge tire/HP advantage.
My point is does the Honda handle bad, yes, but put 10 x 3.5 wheels with a 145 tire on any car and it would handle even worse. 1,375 lb's and stiff suspension helps, but the car sits too high, the track is narrow and the front to rear weight bias is 64/36. That is a huge disavantage!
Roman, like you I enjoy a challenge, so I plan on keeping my 600 stock. Then it will be more fun to "race" the big cars on the road as I go to work.
Lets look at how fast small cars of the day could go around a 100 ft radius. (Road & Track) in MPH:
*Subaru 4wd wagon 30.2
*Honda 600 coupe 30.7
*AMC pacer 31.3
*Ford Pinto 32.0
*Capri 2.8 V6 32.5
*Chevette rally 32.6
*VW Scirocco 32.8
*VW bettle ?
*Vega ?
*Gremlin?
Maybe I will put some Yokahoma's on my coupe, lower it, and.....
brad fenn
Re: Can the Honda 600 handle?
Post by brad fenn »
I never had much complaint about thier handling.I run everything to the max. I raced for years,ran modified dirt circle track. Short coarse off road, mud bogg, Drag bracket racing and a few years street racing. I have my Datsun 510 to go roadcoarse racing, and plan to autocross the 600 coupe.On my 600 coupe I am running 7" Hoosiers and also have slicks for it. Mine is lowered about 4" and has a coilover rear suspension. I dont know how it will handle,but I will find out. Also I had a 600 coupe years back that I ran the wheels reversed like we used to do the old VWs
Lyle To:
Thu, March 24, 2011 10:02:35 PM Subject:
[anzhonda600owners] Can the Honda 600 handle?
*Subaru 4wd wagon 30.2 *Honda 600 coupe 30.7 *AMC pacer 31.3 *Ford Pinto 32.0 *Capri 2.8 V6 32.5 *Chevette rally 32.6 *VW Scirocco 32.8 *VW bettle ?
*Vega ?
*Gremlin?
:) Lyle
Post by Lyle »
Brad, it's to bad you live so far away, you have some cool toys.
Just, not enough hours in a day to use them all.
Had a thought, most guy's dream of racing or driving a car as fast as you can, but money or life gets in the way.
Not anymore, with a Honda 600!
Like most people I have a boring drive of about 9 miles to work.
Speed limits range from 25 to 65mph.
But, driving my 600 coupe I can have a race twice a day!
OK, nobody else will know it, but who cares. I am trying to make every shift perfect at the red line, clutch out at the perfect time, no brake can't loose momentum, look ahead pick the best lane, draft the minivan to the front of the pack....
Everyday I can try to improve on my best lap time.
Plus I can run the car to the redline in every gear and not get a speeding ticket!
This could be fun.
I can't wait to go to work!
> From: Lyle
> Sent: Thu, March 24, 2011 10:02:35 PM
> Subject: [anzhonda600owners] Can the Honda 600 handle?
> *AMC pacer 31.3
> *Ford Pinto 32.0
> *Capri 2.8 V6 32.5
> *VW Scirocco 32.8
> *VW bettle ?
> *Vega ?
> *Gremlin?
Jerry A
Post by Jerry A »
they have potential ! I follow a lot of japanese pages on the z/n 360 race cars and they can be fast race cars. they pump them to 500cc with over 50hp then lower and put them on diet. I assume they are decently fast at that point. I mean if your gonna have a series for a particular car they have to be somewhat fast. my car is in the works but mine will be lowered on my cosmic wheels with camber plates from japan, with z360 grill and rear plate cover. oh ya I also have twin port head and carb set up from japan. thinking a 50+ hp car will actually be a lot of fun.
>This could be fun.
>Lyle
>--- In
>> From: Lyle
>> To:
>> *AMC pacer 31.3
>> *Ford Pinto 32.0
>> *Capri 2.8 V6 32.5
>> *VW Scirocco 32.8
>> *VW bettle ?
>> *Vega ?
>> *Gremlin?
>> Lyle
brad fenn
Post by brad fenn »
Yes,too many toys to use. I run the crap out of one until it brakes and fix another to play with it for a while. I kind of rotate through my cars like that.The one that keeps going no matter how hard I punish it is the 70 Opel GT. 374K on original engine.  My shop is at my home,so no commute for me anymore. But travel a lot to car shows.
Lyle To:
Thu, March 24, 2011 11:31:29 PM Subject:
[anzhonda600owners] Re: Can the Honda 600 handle?
This could be fun.
:) Lyle
xkazoox7
Post by xkazoox7 »
That's true they have a lot of parts out there and a lot of the cars out there look like they can move and handel really good. Time to plan a trip!
Sent from my Verizon Wireless BlackBerry
Jerry A
Sender:
Date:
Thu, 24 Mar 2011 21:51:32 -0700 (PDT)
ReplyTo:
Re: [anzhonda600owners] Re: Can the Honda 600 handle?
>This could be fun.
>Lyle
>--- In
>> From: Lyle
>> To:
>> *AMC pacer 31.3
>> *Ford Pinto 32.0
>> *Capri 2.8 V6 32.5
>> *VW Scirocco 32.8
>> *VW bettle ?
>> *Vega ?
>> *Gremlin?
>> Lyle
It's nice to pick the car you want to drive in the morning.  The Honda 600 is up there with the other under powered cars and trucks.  Anything that will land a ticket on the free way is the wrong vehicle for us older kids.  I manage to get about 70 miles on my Vette each year and a few thousand on my Honda 600's.  The only time I had a Honda 600 above 78 mph was when I mixed the speedometer gears.  A constant trans mission speedometer gear has one less tooth and makes you think your Honda 600 is flying down the road.
If the struts, shocks and rack pinion bushings are good they handle ok.  And 5 inch or wider rims with the same 145X10 tire are better as they keep more rubber on the road.  At speed them skinny (3.5 inch) rims have my Honda's riding the grooves in the freeway like a slot car.
But I am one of the lucky ones; my bride of 39 years, looks at my toys with a smile on her face and keeps the jokes to a minimum.  Any woman who would put up with 20 motors , 4 tool boxes and a restoration project that has been in the works since 1995 and still resting in the garage is a Saint.
> xkazoox7@...
> Thursday, March 24, 2011 8:58
> That's true they have a lot of parts out there and a lot of the cars out > there look like they can move and handel really good. Time to plan a trip!
> Jerry A
> Sender:
> Date:
> ReplyTo:
> handle?
> they have potential ! I follow a lot of japanese pages on the z/n 360 race > cars and they can be fast race cars. they pump them to 500cc with over 50hp > then lower and put them on diet. I assume they are decently fast at that > point. I mean if your gonna have a series for a particular car they have to be > somewhat fast. my car is in the works but mine will be lowered on my cosmic > wheels with camber plates from japan, with z360 grill and rear plate cover. oh > ya I also have twin port head and carb set up from japan. thinking a 50+ hp > car will actually be a lot of fun.
> cool toys.
> all.
> >Had a thought, most guy's dream of racing or driving a car > as fast as you can, but money or life gets in the way.
> >Not anymore,
> with a Honda 600!
> miles to work.
> >But, driving
> it, but who cares. I am trying to make every shift perfect at the red line, > clutch out at the perfect time, no brake can't loose momentum, look ahead pick > the best lane, draft the minivan to the front of the pack....
> >Everyday
> >This could be
> fun.
> work!
> >Lyle
> >--- In
> brad fenn wrote:
> >> I never
> >> raced for years,ran modified dirt circle track. Short coarse off > road, mud bogg, > >> Drag bracket racing and a few years street > racing. I have my Datsun 510 to go > >> roadcoarse racing, and plan to > autocross the 600 coupe.On my 600 coupe� I am > >> running 7" > Hoosiers and also have slicks for it. Mine is lowered about 4" and
> >> has a coilover rear suspension. I dont know how it will > handle,but I will find > >> out. Also� I had a 600 coupe years > back that I ran the wheels reversed like we > >> used to do the old > VWs
> >> From: Lyle
> >> To:
> >> I will
> >> Roman
> >> car. But, if I pick a tight twisty track with very little > straight sections, I > >> think my Go-kart with 4.5 in slicks up front > with 6.5 rears will beat his race > >> car. I am 1" off the ground, > lay flat on my back and the kart with me in it > >> weighs only 365 > lb's. Even though he has a huge tire/HP advantage.
> >> My
> >> tire on any car and it would handle even worse. 1,375 lb's and > stiff suspension > >> helps, but the car sits too high, the track is > narrow and the front to rear > >> weight bias is 64/36. That is a huge > disavantage!
> >> will be more fun to
> >> Lets
> >> *Subaru 4wd wagon
> 30.2
> >> *AMC pacer 31.3
> *Ford Pinto 32.0
> >> *Capri 2.8 V6 32.5
> >> *Chevette rally
> 32.6
> >> *VW Scirocco 32.8
> >> *VW bettle ?
> >> *Vega
> >> *Gremlin?
Post by Lyle »
Bill, nice to have someone back you up for 39 years!
She puts up with you and your hobbies, that's all that most men want.
My coupe is getting closer to completion, the body work is slowing me down. The engine/transaxle has been done for months.
The tires I have for my coupe look OK but they are older. So they have gotten harder. When i get on the road I will get some better tires, maybe wider wheels.
Motor Trend had a good artical about modifying the suspension for handling in the .83G range.
No rush to modify my coupe, I might like it the way it is!
]On Behalf Of xkazoox7@...
> Sent: Thursday, March 24, 2011 8:58 PM
> Subject: Re: [anzhonda600owners] Re: Can the Honda 600 handle?
> From: Jerry A
> Sender:
> Date: Thu, 24 Mar 2011 21:51:32 -0700 (PDT)
> To: ReplyTo:
> speeding ticket!
> >This could be fun.
> >Lyle
> >--- In
, brad fenn
> max. I
> mud bogg,
> to go
> >> roadcoarse racing, and plan to autocross the 600 coupe.On my 600 coupe�
> I am
> 4" and
> will find
> >> out. Also� I had a 600 coupe years back that I ran the wheels reversed
> like we
> >> From: Lyle
> >> To:
> handles.
> powered
> sections, I
> his race
> in it
> with a 145
> suspension
> rear
> Then it
> radius.
> >> *AMC pacer 31.3
> >> *Ford Pinto 32.0
> >> *Capri 2.8 V6 32.5
> >> *VW Scirocco 32.8
> >> *VW bettle ?
> >> *Vega ?
> >> *Gremlin?
> >> Lyle
brad fenn
Post by brad fenn »
Lyle,If you get it back to like new condition,you will probably be totally satisfied like it is.
Lyle To:
Fri, March 25, 2011 10:29:47 PM Subject:
, wrote:
> It's nice to pick the car you want to drive in the morning. The Honda 600 > is up there with the other under powered cars and trucks. Anything that > will land a ticket on the free way is the wrong vehicle for us older kids.
> I manage to get about 70 miles on my Vette each year and a few thousand on > my Honda 600's. The only time I had a Honda 600 above 78 mph was when I > mixed the speedometer gears. A constant trans mission speedometer gear has > one less tooth and makes you think your Honda 600 is flying down the road.
> If the struts, shocks and rack pinion bushings are good they handle ok. And > 5 inch or wider rims with the same 145X10 tire are better as they keep more > rubber on the road. At speed them skinny (3.5 inch) rims have my Honda's > riding the grooves in the freeway like a slot car.
> But I am one of the lucky ones; my bride of 39 years, looks at my toys with > a smile on her face and keeps the jokes to a minimum. Any woman who would > put up with 20 motors , 4 tool boxes and a restoration project that has been > in the works since 1995 and still resting in the garage is a Saint.
> From: Jerry A
> Sender:
> To: ReplyTo:
> they have potential ! I follow a lot of japanese pages on the z/n 360 race > cars and they can be fast race cars. they pump them to 500cc with over 50hp > then lower and put them on diet. I assume they are decently fast at that > point. I mean if your gonna have a series for a particular car they have to > be somewhat fast. my car is in the works but mine will be lowered on my > cosmic wheels with camber plates from japan, with z360 grill and rear plate > cover. oh ya I also have twin port head and carb set up from japan. thinking > a 50+ hp car will actually be a lot of fun.
> >Had a thought,
> >OK, nobody else will know it, but who cares. I am trying to make every > shift perfect at the red line, clutch out at the perfect time, no brake > can't loose momentum, look ahead pick the best lane, draft the minivan to > the front of the pack....
> >Plus I can run the car to the redline in every gear and not get a > speeding ticket!
> >This could be fun.
> >Lyle
> >--- In
, brad fenn
> >> I never had much complaint about thier handling.I run everything to the > max. I > >> raced for years,ran modified dirt circle track. Short coarse off road, > mud bogg, > >> Drag bracket racing and a few years street racing. I have my Datsun 510 > to go > >> roadcoarse racing, and plan to autocross the 600 coupe.On my 600 coupe� > I am > >> running 7" Hoosiers and also have slicks for it. Mine is lowered about > 4" and > >> has a coilover rear suspension. I dont know how it will handle,but I > will find > >> out. Also� I had a 600 coupe years back that I ran the wheels reversed > like we > >> used to do the old VWs
> >> From: Lyle
> >> To:
> >> OK, Roman brought up some interesting points about how bad the Honda > handles.
> >> Roman races and so do I, OK mines an enduro go-Kart and his is a high > powered > >> car. But, if I pick a tight twisty track with very little straight > sections, I > >> think my Go-kart with 4.5 in slicks up front with 6.5 rears will beat > his race > >> car. I am 1" off the ground, lay flat on my back and the kart with me > in it > >> weighs only 365 lb's. Even though he has a huge tire/HP advantage.
> >> My point is does the Honda handle bad, yes, but put 10 x 3.5 wheels > with a 145 > >> tire on any car and it would handle even worse. 1,375 lb's and stiff > suspension > >> helps, but the car sits too high, the track is narrow and the front to > rear > >> weight bias is 64/36. That is a huge disavantage!
> Then it
> >> Lets look at how fast small cars of the day could go around a 100 ft > radius.
> >> *AMC pacer 31.3
> >> *Ford Pinto 32.0
> >> *Capri 2.8 V6 32.5
> >> *VW Scirocco 32.8
> >> *VW bettle ?
> >> *Vega ?
> >> *Gremlin?
> >> Lyle
Post by Lyle »
Brad, I will leave it stock unless I feel it's so bad it's not safe.
Or everyone on the road is honking there horn at me for going to slow.
Question, when you are at the limit of the tires grip, does the front end "push" under steer, like most front wheel drive cars?
I am at the shop working on my coupe, inner rocker repair.
> From: Lyle
> Sent: Fri, March 25, 2011 10:29:47 PM
> Subject: [anzhonda600owners] Re: Can the Honda 600 handle?
> the .83G range.
> > [mailto:
> > From: Jerry A
> > Sender:
> > To: > ReplyTo:
> > speeding ticket!
> > >This could be fun.
> > >Lyle
> > >--- In
, brad fenn
> > max. I
> > mud bogg,
> > to go
> > >> roadcoarse racing, and plan to autocross the 600 coupe.On my 600 coupeÂ
> > I am
> > 4" and
> > will find
> > like we
> > >> From: Lyle
> > >> To:
> > >> Â
> > handles.
> > powered
> > sections, I
> > his race
> > in it
> > with a 145
> > suspension
> > rear
> > Then it
> > radius.
> > >> *AMC pacer 31.3
> > >> *Ford Pinto 32.0
> > >> *Capri 2.8 V6 32.5
> > >> *VW Scirocco 32.8
> > >> *VW bettle ?
> > >> *Vega ?
> > >> *Gremlin?
> > >> Lyle
