Need brake cylinders and master cylinder
dwb_07
!!!!!! Re: [2cylinderhondas] Re: mechanical symptom advice ???
Post by dwb_07 »
I am going paint with a broad brush here. It can't be loose wire or connection. They rarely just turn the engine off and are typically intermittent. That would result in gas collecting and a misfire or back fire.
Does it run ok when it is cold or only fail when it is hot? Coils sometimes fail when hot and they just shut down.
Again a broad brush. If it dies at idle and high RPM it shouldn't be a carburetor idle circuit or main circuit, but it could be a sticking float. The part of the carb that assures a gas supply to the secondary parts of carb. Do you have a see through fuel filter? Is it empty when the motor shuts down?
, "Jennifer F. Kidder" wrote:
> YOU ARE AWSOME!! you are all unbelievable & I'm a little overwhelmed.
> 1.  my car Would stall on the freeway...+ I haven't even told you guys about the breaks yet.
> cazy as it is with this car, I have neither a 'trailer' nor a 'towbar' nor a friend w/ a pickup. I don't think my AAA coverage extends that far,  but I can check! If I can figure out a way to get my car to you, Miles, I will Fly there!!
> 2. Chas,  I live in Berkely CA 1mi west of the University  (where are you?)
> [&, yes!!, I would love someone to take a look at it here! -maybe show me this thing you said about the sparkplugs or David's break-light backing-    ......oye vey, the breaks...  ]
> 3.  dwb,   Yes, cuts out at hi rpm; has never popped or backfired; doesn't 'slowly die'--Dies!; can't Always be
> saved by peddling gas;  doesn't Always start & rev up smoothly.
> & I don't understand your definition of an 'electrical disconnect' as different from an 'intermittant electrical connection'. If the car ever moves at all, (which it does) wouldn't any electric cause of stalling Have to be intermittant?
> ok, gotta go running now; I feel a renewal of energy.
> & really, again, you guys are amazing.
> --talk soon, skip
> >From: feltonminicycle
> >To:
> >Sent: Sunday, August 11, 2013 1:00 AM
> >Subject: [2cylinderhondas] Re: mechanical symptom advice ???
> >Jennifer,
> >I never worked on your car and you are only 1.25 hours drive unless you consider stalling at freeway speeds? Trailer or towbar it down to Boulder Creek - let's figure it out.
> >Miles
> >--- In
> >> WOW! You guys rock! just got these & will begin ruminating over
> >> --skip
> >> > From: Charles Gould
> >> >To: "
" >> >Cc: "
" >> >Sent: Saturday, August 10, 2013 11:54 AM
> >> >Subject: Re: [2cylinderhondas] mechanical symptom advice ???
> >> >Â
> >> >Are you sure it is only during idle? because you said that it stalled while you were barreling along in the fast lane. If it were a fuel starvation issue, it would occur at higher RPMs as well. If it were a clogged idle jet, it would just happen at idle.Â
> >> >Sounds like an intermittent electrical problem to me. Possibly a bad ground from engine or more likely, a loose wore or short at the points or condenser. Check for broken wire insulation or a missing or bad insulator washer.Â
> >> >It could also very likely be a bad ignition coil or condenser, which would be worse as the coil heats up.Â
> >> >Chas
> >> >Sent from my iPhone
> >> >On Aug 10, 2013, at 2:30 PM, "Jennifer F. Kidder" wrote:
> >> >Â
> >> >>hey folks,
> >> >>I don't know if you guys do this, I'm hoping your collective expertise can tell me what I'm missing:
> >> >>my '71 N600  Won't Idle!.  I feel like I've been trying to keep it from stalling for 10 years!  but that parinoia might be because that's  how long it has sporatically stalled While I'm  Barreling Along in the Fast Lane!  at the advice of various mechanics, I &/or they have:  swapped out the fuel pump, batttery,  spark plugs / leads,  cleaned carborater & air filter, ...I don't know what else!  & these things haven't worn out again; barely driven over past several years because it's so depressing : sometimes the problem is solved for 3blocks!, 10 miles, 1 month,...
> >> >>last thing  done was new fuel filter. (~2weeks
> >> ago) & I paid a mechacic alot to get to the bottom of this problem; that's all he did, & now it's theatening to stall again!  {I really donot wish to disparage this last guy. everyone who  has worked on or helpedme work on this issue, says "yeah, that's not a problem anymore" or worse"it never was"}
> >> >>anyway, I had thought the fuel filter made sense. :(
> >> >>Now What???
> >> >>--skip
Post by feltonminicycle »
I have new switch backs in stock, kinda coveting them but would share :-)
, David Baer wrote:
> try checking the back of the ignition switch to ensure the bake-lite
> backing is securely staked into place. That was my mystery cut-out problem
> On Sat, Aug 10, 2013 at 11:30 AM, Jennifer F. Kidder
> > hey folks,
> > last thing done was new fuel filter. (~2weeks ago) & I paid a mechacic
> > Now What???
> > --skip
> David F. Baer
> 469 Ena Rd., Apt. #1311
> Honolulu, HI 96815
> Cell: XXX-XXX-XXXX
Connor McCann
Post by Connor McCann »
I don't think it's the gas tank, but a clean gas tank is always good. �There are specialty shops that can restore gas tanks if you ship it to them. �It doesn't matter what kind. �Most cut it open, scrub it, clean it, and close it up again making it good as new. �Some places apply coatings to preserve it too. �A clean gas tank means you're feeding your car clean fuel.
Though if you're having this issue while you're on the highway, then it's likely something else. �Sounds like electrical connection is a popular choice.
-Connor
On Mon, Aug 12, 2013 at 4:05 AM, feltonminicycle
> > backing is securely staked into place. �That was my mystery cut-out problem
> > > hey folks,
> > > my '71 N600 �Won't Idle!. �I feel like I've been trying to keep it from
> > > stalling for 10 years! �but that parinoia might be because that's �how long
> > > it has sporatically stalled While I'm �Barreling Along in the Fast Lane!
> > > at the advice of various mechanics, I &/or they have: �swapped out the fuel
> > > pump, batttery, �spark plugs / leads, �cleaned carborater & air filter,
> > > ...I don't know what else! �& these things haven't worn out again; barely
> > > last thing �done was new fuel filter. (~2weeks ago) & I paid a mechacic
> > > theatening to stall again! �{I really donot wish to disparage this last
> > > guy. everyone who �has worked on or helpedme work on this issue, says
> > > Now What???
> > > --skip
> > David F. Baer
> > Honolulu, HI 96815
> > Cell: �XXX-XXX-XXXX
Post by Eric Geiger »
Quit guessing what's wrong and just schedule a time to go visit miles.   He's the best possible person to have look at it and he's right in your back yard.
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX phone
XXX-XXX-XXXX fax
XXX-XXX-XXXX mobile
egeiger@...
www.prgnocturne.com
On Aug 12, 2013, at 7:58 AM, "Connor McCann" wrote:
I don't think it's the gas tank, but a clean gas tank is always good.  There are specialty shops that can restore gas tanks if you ship it to them.  It doesn't matter what kind.  Most cut it open, scrub it, clean it, and close it up again making it good as new.  Some places apply coatings to preserve it too.  A clean gas tank means you're feeding your car clean fuel.
Though if you're having this issue while you're on the highway, then it's likely something else.  Sounds like electrical connection is a popular choice.
-Connor
> > > hey folks,
> > > Now What???
> > > --skip
> > David F. Baer
> > Honolulu, HI 96815
> > Cell:  XXX-XXX-XXXX
malski312
Post by malski312 »
There is a small filter screen at the needle valve inside the carb. This might be getting clogged or is collapsing. It requires pulling the carb and taking needle valve and floats off to get to it.
Just a guess Mark
> hey folks,
> my '71 N600� Won't Idle!.� I feel like I've been trying to keep it from stalling for 10 years!� but that parinoia might be because that's� how long it has sporatically stalled While I'm� Barreling Along in the Fast Lane!� at the advice of various mechanics, I &/or they have:� swapped out the fuel pump, batttery,� spark plugs / leads,� cleaned carborater & air filter, ...I don't know what else!� & these things haven't worn out again; barely driven over past several years because it's so depressing : sometimes the problem is solved for 3blocks!, 10 miles, 1 month,...
> last thing� done was new fuel filter. (~2weeks ago) & I paid a mechacic alot to get to the bottom of this problem; that's all he did, & now it's theatening to stall again!� {I really donot wish to disparage this last guy. everyone who� has worked onor helpedme work on this issue, says "yeah, that's not a problem anymore" or worse"it never was"}
> Now What???
> --skip
infinkc
Re: Coker (King 145R-10 Tires)
Post by infinkc »
Bill,
What model is $64? i dont see any on summit that are that cheap. They have a 50278, but those are 87 ea.
, "Bill" wrote:
> Pricing note:
> Summit Racing Equipment
http://www.summitracing.com/
or call for order at
> 1.XXX-XXX-XXXX to order these tires at $64.00 each to beat the Coker price
> and right now they have a special free shipping for orders over $99.00. So
> your order will be $256.00 to your door unless there is tax. That is about
> the best deal going.
Mark P Hatten
Post by Mark P Hatten »
Yes I called Summit. The  145r-10 Kingstire they have is through Coker and are $ 87. bucks each
The Summit website was wrong. They were going to fix that after my call.
Mark Portland Or.
https://www.youtube.com/watch?v=6Rs0yWG0jwQ
www.mphspecialties.com
To: 2cylinderhondas@yahoogroups.com From: infinkc@...
Date: Fri, 16 Aug 2013 14:42:49 +0000 Subject: [2cylinderhondas] Re: Coker (King 145R-10 Tires)
Bill,
, "Bill" wrote:
> Pricing note:
Mark;
You have to ask for a price match because Coker sells them for $65.00 and that is how I beat the price.  And the shipping is free over $99.00.
Mark P Hatten
Mark P Hatten
Hi Bill
I just ordered a set of 4 Kingstires   145r 10 Radials from Summit thru Coker, $ 260. for the set, to my door.   Free shipping.
Saved me $ 150. in shipping costs if I'd bought from Coker.
Thank you .
Mark
