As a newer owner to a set of Honda 600, I think that I may have caused my own problems. A few month's ago I bought a 72 600N, it had been sitting out in a dirt lot for a few years. The guy I got it from had long ago lost the keys, so I drilled out the two retaining bolts to unlock the steering. Then I lucked out and got a 72 600Z at a storage auction (only $5.00 for the car!) same thing no keys, get the drill out to get the car home.
Now is where I have the problem, the first car got it cleaned up put together use a screwdriver to turn the switch, no spark. Rechecked everything same problem. When I got the second car same thing again. So my question is, if the ignition assembly is not bolted on and turned with the key will this cause no spark problem? I think it is a far fetched idea, but I got the same results with both cars.
Thanks for any help or ideas,
Jason
Do You Yahoo!?
Yahoo! Finance - Get real-time stock quotes
Starting problems!
Re: Starting problems!
Hi Jason;
I think every owner will tell you that if you unbolt the ignition switch from the key way you can use a screw driver to turn it to start your car. I think there is something else in the mix. Try touching the hot lead to the battery bolt on your starter if it turns then switch the ignition switch on and see if it will start. If not, then you need to look else where.
> jason
> hambelton
> 2cylinderhondas
> Sunday, September 01, 2002 1:09
> [2cylinderhondas] Starting
> problems!
> As a newer owner to a set of Honda 600, I think that I may have > caused my own problems. A few month's ago I bought a 72 600N, it had > been sitting out in a dirt lot for a few years. The guy I got it from > had long ago lost the keys, so I drilled out the two retaining bolts to unlock > the steering. Then I lucked out and got a 72 600Z at a storage auction > (only $5.00 for the car!) same thing no keys, get the drill out to get the car > home.
> Now is where I have the problem, the first car got it cleaned up put > together use a screwdriver to turn the switch, no spark. Rechecked > everything same problem. When I got the second car same thing > again. So my question is, if the ignition assembly is not bolted on and > turned with the key will this cause no spark problem? I think it is a > far fetched idea, but I got the same results with both cars.
> Jason
> Do You Yahoo!?
> Yahoo!
> Finance
> To
> to:
> Your
> Yahoo! Terms of Service
That's what I thought. They both turn over and and have good compresion, just can't get the spark yet. I will be re-installing the engine soon, so by then all the wires and connections will have been gone thru and cleaned or replaced. Along the way I hope to find the problem. Thanks for the info, it takes one idea out of the way.
Jason
william colford wrote:
Jason
> Hi Jason;
> > jason hambelton
> > 2cylinderhondas
> > Sunday, September 01, 2002 1:09 PM
> > [2cylinderhondas] Starting problems!
> > Jason
> > Do You Yahoo!?
> > Yahoo! Finance
> > Your use of Yahoo! Groups is subject to the
Do You Yahoo!?
Yahoo! Finance
I'll offer my 2 cents here. I had the engine on mine worked on and
then had problems getting it started. After checking everything ( I
thought) the problrm was solved by putting in new sparkplugs. We had
sure looked at the plugs, but they must have been fouled. Seemed too
simple. But it did the trick.
There is a misperception about spark plug cleaning. A lot of shade-tree
mechanics make the mistake of using carb cleaner and a wire brush to clean
them up. Even raw gas is not the best. The best way is to get one of the
compressed air spark plug sand blasting tools. It cleans them up great and
keeps them dry. The difference between your old plugs and the new ones you
replaced them with was most likely that they were dry. I say this not to
pick at your comment because it was right on the mark, but for the situation
that we already had new plugs in when it wouldn't start, I too have had the
wet plug problem, and a quick sand blasting has done the trick.
I've been sandblasting plugs for years, works great. I dump as many
as I can collect in my bead blaster and do 'em up all at once (using
60 mesh sand) however if there is any residual sand you don't want it
in the engine. I wash them in Oil Eater, rinse with hot water, & blow
dry the plugs then inspect the tips. Rounded tip electrodes don't
produce at crisp spark as a new one. Look at a new plug (an NGK) it
has a flat tip.
I hear heating the ceramic tip insulator & tip with a butane lighter
will burn off oil residue. Great roadside trick - could get you home.
Motor on -
has a flat tip.
Motor on -
tree
to clean
of the
great and
ones you
not to
situation
had the
> From: "isettajoe"
> Sent: Tuesday, September 03, 2002 4:35 PM
> Subject: [2cylinderhondas] Re: Starting problems!
I
had
too
have
had
retaining
600Z at
get
problem?
> > both cars.
> > > Jason
> > > Do You Yahoo!?
> > 2cylinderhondas-unsubscribe@y...
