I have been driving my 600 for a few months now and everything is great. I got all the little things fixed and cleaned and I couldn't be happier with my purchase.....the only problems I seem to have are these:
1. My car seems to take a VERY long time to warm up and run properly. I have to pull the choke and leave it out for atleast 3-5 min before I can go anywhere or it will stall when i come to a stop. Not sure if this is just a common thing with the little 2 cyl air cooled engines, but just thought I would ask if anyone knows what may be causing this.
2. When accelerating and at higher speeds, the car runs perfect, however if I am going through a slower speed limit zone and I keep the throttle at 50% or lower, it seems to have a wierd hesitation. Like its starving for fuel or something, almost chuggs along when this happens. I have changed the fuel filter with no difference. I am somewhat mechanical, but have never really worked on an engine like this, so I don't know where to start!
Any help would be GREAT!!!!
N600 with a slight hesitation
Re: N600 with a slight hesitation
take the fuel bowl off and clean the tiny screen under the needle and seat.......
Thu, 8/20/09, stackhouse_16
> From: stackhouse_16
> Subject: [2cylinderhondas] N600 with a slight hesitation
> Date: Thursday, August 20, 2009, 6:52 AM
> I have been driving my 600 for a few months now and everything is great. I got all the little things fixed and cleaned and I couldn't be happier with my purchase.... .the only problems I seem to have are these:
Mine was like this when the valve lash was wrong, slightly too tight I think. Follow the procedure in the manual, no shortcuts.
> From: stackhouse_16
> Date: Thursday, August 20, 2009, 8:52 AM
Kevin Lister
I had the exact same symptoms and it turned out to be a vacuum leak. The intake manifold on my car had some cracks in the rubber on the underside that I didn' t see when I put it in. It may look perfect on the inside of the manifold but that doesn't matter as air can go through holes that you can't see. I replaced the intake manifold and the long warm-up time and hesitation, dying at a stop, etc, all went away immediately!
kev
kev
Thu, 8/20/09, Kenneth Sievert
Subject: Re: [2cylinderhondas] N600 with a slight hesitation To: 2cylinderhondas@yahoogroups.com Date: Thursday, August 20, 2009, 8:36 AM
> From: stackhouse_16
> 2. When accelerating and at higher speeds, the car runs perfect, however if I am going through a slower speed limit zone and I keep the throttle at 50% or lower, it seems to have a wierd hesitation. Like its starving for fuel or something, almost chuggs along when this happens. I have changed the fuel filter with no difference. I am somewhat mechanical, but have never really worked on > an engine like this, so I don't know where to start!
