The red lighted button on the dash is a test to see if the brake failure light works. If it stays on there is no pressure in a part of the system. Or the sender on the side of the Master Cylinder is bad. If you have good brakes then it may be the sender. It's all right there in the first section of the owners manual page 23 for the Sedan.
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > Steve Wander > Sent:
> Wednesday, June 14, 2006 6:53
> [2cylinderhondas] Re: RED LITE ON DASH
> I believe The red light on the dash is the fluid
> level indicator. when you push on the brake pedal the fluid is displaced to > the cylinders so the fluid drops a bit. I think it is a DOT safety indicator > as it looks kinda aftermarket.
> > waynel@...
> > Tuesday, June 13, 2006 4:01
> > PM
> > Re: [2cylinderhondas] Re: RED
> > LITE ON DASH
> > I believe the red light is to indicate an excess differential > > pressure > > between the braking systems. It has a "push-to-test" > > feature so the > > operator can verify the bulb is OK. My experience is > > that this light > > should never come on.
> > Wayne
> > ---- Original Message
> > matt@gassavers. org
> > Re: [2cylinderhondas] Re: RED LITE ON DASH
> > Date: Tue, 13 Jun 2006
> > 15:54:22 -0700
> > >Oddly, my red light only comes on when I have my
> > foot on the brake
> > >for a few seconds. So I'm always idling when it
> > comes on. Is this
> > >the turbo indicator you speak
> > of?
> > >Also, I don't see a blue light on my dash. Was this only > > offered in > > >late 71 and 72 models? I'm pretty certain I don't have > > high beams > > >either.
> > >Matt Timion
> > Original Message -----
> > > From: infinkc
> > > Sent: Tuesday, June 13, 2006 12:13 PM
> > "kneeandme"
> > > wrote:
> > > > THERE ARE TWO SMALL LITES ON THE DASH, A RED AND A BLUE .
> > THE
> > >BLUE
> > > IS
> > > > FOR HIGH BEAMS , WHAT IS THE RED
> > ONE FOR ?
> > > That is the turbo indicator, when the
> > blower for the heater is
> > > switched over to turbo mode the light
> > comes on. Most likely its the
> > > emergency brake indicator
> > light tellign you that its still engaged.
> > > should be noted in
> > your owners manual, if your car has it still, if
> > > not
> > http://www.honda600 coupe.com/
> > steves site has them in pdf.
