oil cooler
Ryan Haggard
oil cooler
Post by Ryan Haggard »
sorry to bug ya, I have a 72 coupe that I drive to work on fridays and would love to keep it running cooler... I have cooler lines from a VW cooler set, but I have no idea how to make the adapter to the filter, is there any chance that you might have this part modified to fit the oil filter area.. and if you do anychance on buying it from you..
Re: oil cooler
Ryan;
You can do this your self.
If you purchase the parts from me it will cost.
> Ryan
> Haggard
> Thursday, June 25, 2009 9:08 PM
> [anzhonda600owners] oil
> cooler
> sorry to bug ya, I have a 72 coupe that I drive to work on fridays > and would love to keep it running cooler... I have cooler lines from a > VW cooler set, but I have no idea how to make the adapter to the > filter, is there any chance that you might have this part modified to > fit the oil filter area.. and if you do anychance on buying it from > you..
Ryan Haggard
Re: oil cooler
ok well um do you have one that you can take a pic of so I have an idea of how it should ruffly look after modifying it?
Thu, 6/25/09, billmyong@...
> From: billmyong@...
> Subject: RE: [anzhonda600owners] oil cooler
> Date: Thursday, June 25, 2009, 11:48 PM
> Ryan;
> > anzhonda600owners@
> > yahoogroups
> > . com [mailto:anzhonda600 owners@yahoogrou ps.com]
> > On Behalf Of
> > Ryan Haggard
mterrens
Re: oil cooler
Post by mterrens »
They're in the group's photos section...
www.honda600coupe.com
> Ryan Haggard
> Friday, June 26, 2009 11:31
> cooler
> I have an idea of how it should ruffly look after modifying > it?
> --- On
> Thu, 6/25/09,
> billmyong@earthlink .net
> > Date:
> > Ryan;
> > will cost.
> > > anzhonda600owners@
> > > yahoogroups
> > > ps.com]
> > > On Behalf Of
> > > Ryan Haggard
> > > Sent:
> > > Thursday,
> > > com
> > > cooler
> > > sorry to bug ya, I have a 72 coupe that I drive to work > > > on fridays and would love to keep it running cooler... I have > > > cooler lines from a VW cooler set, but I have no idea how > > > to make the adapter to the filter, is there any chance that > > > you might have this part modified to fit the oil filter area..
Re: oil cooler
Steve, thanks.
Ryan;
The kit includes all the items including assembly directions necessary to complete the installation.  4 hours is a good time if you are handy with some modifications.  As I said in other e-mails this is a oil cooler it will not add metal to warn parts.  It will help to keep your oil from turning your engine internals looking like the just came out of a tar pit.  Heat is the biggest part of engine wear.   Making sure the oil is kept at a usable temperature is the best thing you can do for your Honda 600 engine.  Yes, the oil in your Honda 600  .is used as not only as engine lubricant but also for the transmission.  20W50 is the weight of oil I like to use, it retains viscosity (that which allows the oil lubricant products to stick to the metal parts.  Heat thins the oil to a great extent lessening its lubrication qualities.  Too cold keeps the oil from getting to where it needs to go, to hot and it washes away.
Both can have damaging affects to the engine.
So having an oil thermostat helps to keep the oil at the proper temperature.
Regards
> Steven
> Michelsen
> Friday, June 26, 2009 9:13 AM
> Re: [anzhonda600owners]
> oil cooler
> section...
> http://groups. yahoo.com/ group/anzhonda60 0owners/photos/ album/XXX-XXX-XXXX /pic/list
> Steve
> www.honda600coupe. com
> > Ryan Haggard
> > AM
> > cooler
> > so I have an idea of how it should ruffly look after modifying > > it?
> > --- On
> > Thu, 6/25/09,
> > > Date:
> > > Ryan;
> > > will cost.
> > > Bill
> > > > From:
> > > > anzhonda600owners@
> > > > yahoogroups
> > > > . com
> > > > [mailto:anzhonda600 owners@yahoogrou ps.com] > > > > On Behalf Of
> > > > Ryan Haggard
> > > > Sent:
> > > > PM
> > > > To:
> > > > com
> > > > Subject:
> > > > cooler
> > > > sorry to bug ya, I have a 72 coupe that I drive to work > > > > on fridays and would love to keep it running cooler... I > > > > have cooler lines from a VW cooler set, but I have no > > > > idea how to make the adapter to the filter, is there any > > > > chance that you might have this part modified to fit the oil > > > > filter area.. and if you do anychance on buying it from > > > > you..
jpro8071
Re: oil cooler
Post by jpro8071 »
My two bits is to buy the adapter from Bill. We've been running one of his for years in a very abusive environment (Bonneville, El Mirage and Petaluma - the "pot hole capital of the US") - and believe me, I beat on the car pretty hard.
, wrote:
> Steve, thanks.
> Ryan;
> hot and it washes away. Both can have damaging affects to the engine. So
> Regards
]On Behalf Of Steven Michelsen
> Sent: Friday, June 26, 2009 9:13 AM
> Subject: Re: [anzhonda600owners] oil cooler
> list
> Steve
> From: Ryan Haggard
> Sent: Friday, June 26, 2009 11:31 AM
> --- On Thu, 6/25/09, billmyong@...
> From: billmyong@...
> Ryan;
> From: anzhonda600owners@ yahoogroups. com [mailto:anzhonda600
> owners@yahoogrou ps.com]On Behalf Of Ryan Haggard
> Sent: Thursday, June 25, 2009 9:08 PM
> Subject: [anzhonda600owners] oil cooler
bruceb
Re: oil cooler
Post by bruceb »
What set of photos is the oil cooler under. The link does not seem to work.
mterrens
Re: oil cooler
Post by mterrens »
The link is correct.  Are you signed on yahoo groups when you clicked on the link?  Sign in then try the link...
OR, sign in, go to the group's top page, choose PHOTOS, then find the oil cooler pics.
> brucerb@...
> Monday, July 20, 2009 10:15
> Re: [anzhonda600owners] Re: oil
> cooler
> What set of
> Original Message -----
> From: "jpro8071" jpro8071@yahoo. com
> Tuesday, July 14, 2009 4:58:28 PM GMT -08:00 US/Canada Pacific > Subject:
> [anzhonda600owners] Re: oil cooler
> My two bits is to buy the adapter from Bill. We've been running one of his > for years in a very abusive environment (Bonneville, El Mirage and Petaluma - > the "pot hole capital of the US") - and believe me, I beat on the car pretty > hard.
> > Steve, thanks.
> > Ryan;
> > the biggest part of
> > temperature is
> the best thing you can do for your Honda 600 engine. Yes, > > the oil in > your Honda 600 .is used as not only as engine lubricant but also > > for > the transmission. 20W50 is the weight of oil I like to use, it retains
> viscosity (that which allows the oil lubricant products to stick to > the > > metal parts. Heat thins the oil to a great extent lessening its > lubrication > > qualities. Too cold keeps the oil from getting to where it > needs to go, to > > hot and it washes away. Both can have damaging affects > to the engine. So > > having an oil thermostat helps to keep the oil at > the proper temperature.
> > Regards
> ]On Behalf Of
> Steven Michelsen
> list
> > Steve
> > From: Ryan Haggard
> cooler
> modifying it?
> > --- On Thu, 6/25/09, billmyong@.. .
> billmyong@.. .
> > Subject: RE:
> > Date:
> > Ryan;
> [mailto:anzhonda600
> Haggard
> cooler
> drive to work
> > on fridays and would love to keep it running cooler... I > have cooler lines > > from a VW cooler set, but I have no idea how to make > the adapter to the > > filter, is there any chance that you might have > this part modified to fit > > the oil filter area.. and if you do > anychance on buying it from you..
