Flywheel removal
paul tate
Flywheel removal
Post by paul tate »
Anyone have any good tips on removing the flywheel?
After doing a little more digging on my no charging issue, I found that two of the white wires coming from the alternator are shorted while doing the patented wiggle test. So, it looks like the flywheel needs to come off to gain access to the wires with the missing insulation.
Re: Flywheel removal
Worth the try,  Call up your local Honda Dealer and ask to borrow their puller, most have them.  It is a tool you need to pull the stator (fly wheel)
paul tate
Post by paul tate »
Not a bad idea.  I'll give them a call, worst they can say is no.  Is the puller basically a large bolt that screws into the rotor/ flywheel and pushes against the end of the crankshaft?
Tue, 5/18/10, William
Colford
> From: William Colford
> Subject: RE: [anzhonda600owners] Flywheel removal
> Date: Tuesday, May 18, 2010, 6:56 PM
> anzhonda600owners@ yahoogroups. com [mailto:anzhonda600 owners@yahoogrou ps.com] > On Behalf Of > paul tate > Sent:
> Tuesday, May 18, 2010 4:31 PM
Marshall
Post by Marshall »
Miles was selling them some time ago.
> paul tate
> Wednesday, May 19, 2010 1:58
> removal
> they can say is no.  Is the puller basically a large bolt that > screws into the rotor/ flywheel and pushes against the end of the > crankshaft?
> --- On
> Colford
> billmyong@earthlink .net
> > William Colford > billmyong@earthlink .net
> > 2010, 6:56 PM
> > Worth the
> > try,  Call up your local Honda Dealer and ask to borrow their > > puller, most have them.  It is a tool you need to pull the stator > > (fly wheel)
> > anzhonda600owners@ yahoogroups. com [mailto:anzhonda600 > > owners@yahoogrou ps.com] > > On Behalf > > Of > > paul tate > > Sent:
> > PM
> > [anzhonda600owners]
> > Flywheel removal
> > flywheel?
> > issue, I found that two of the white wires coming from the alternator > > are shorted while doing the patented wiggle test. So, it looks like > > the flywheel needs to come off to gain access to the wires with the > > missing insulation.
Yes,  it was a special bolt with a fine thread.  You might check the past message postings on this subject.  I was under the impression Miles had sold out of the rotor puller but if you go to motorcycle part websites,  they have a rotor puller bolt which will work.
> Not a
> bad idea.  I'll give them a call, worst they can say is no.  Is > the puller basically a large bolt that screws into the rotor/ flywheel and > pushes against the end of the crankshaft?
paul tate
Post by paul tate »
Does anyone know the size and tread pitch of rotor/ rotor removal tool?.
Wed, 5/19/10, goinhm@...
> From: goinhm@...
> Subject: Re: [
> anzhonda
> Date: Wednesday, May 19, 2010, 1:58 AM
> good luck,
Here you go..... 24mm wide,  27mm long (the portion which is involved in pressing off the rotor), and the pitch is 1.5mm.    In the K & L catalog  2009 (pg 101) they have a 24mm, 1.5mm pitch removal tool with part number 35-4266.   I think this tool may work if the threaded portion is long enough.  It is important the length of the removal portion is at least 27 mm so you have enough length to press off the rotor.  Otherwise,  you have to end up adding some washers or metal disks to make up for the lack of length on the rotor removal shaft.
Let us know if you are successful in repairing the wiring issues on your rotor.  That appears to be a major undertaking you are embarking on if you are planning on repairing a broken wire in the rotor.
> Does
> anyone know the size and tread pitch of rotor/ rotor removal > tool?.
paul tate
Post by paul tate »
Thanks a lot for the info!  I will let you know what I find and if I have any luck in repairing it.
> From: goinhm@...
> Subject: Re: [
> anzhonda
> Date: Wednesday, May 19, 2010, 2:51 PM
> good luck,
