I've been tinkering with one of my '71 sedans and a few weeks ago I got it running when I bypassed the plugged up fuel tank. I tried starting it again last week and it quit cranking when I turned the key. I pulled it out and hooked it up to a battery and it seemed to be OK (bendix spun up and moved, etc.), but I installed the starter from my parts car anyway. It started cranking again, but it did so very slowly and would not spin fast enough to start the car. I tried again yesterday and it also quit cranking.....no clicking, just turn the key and nothing happens.
Did I fry both starters? Is this common? What is the prognosis? Do I just need to tear it apart and clean it up and maybe replace the brushes or ?? HELP!!!
Mike Valentine
(2) '71 Sedans!!
Starter problems
Re: Starter problems
It seems a little too coincidental that you have two starters doing the same and at least one of them seems to work fine when out of the vehicle. I would double check the battery, cables, connections and make sure the engine is grounded to the chassis. Then if you don't find the problem, I would take both starters to a rebuild shop to have them tested, as they probably won't charge you much if anything just to test them.
Good luck with it.
Paul
Good luck with it.
Paul
Thu, 8/19/10,
mr
.n600
> From: mr.n600
> Subject: [anzhonda600owners] Starter problems
> Date: Thursday, August 19, 2010, 2:34 AM
> Mike Valentine
> (2) '71 Sedans!!
woodwizard
My first thought was "battery" too.
And generic parts stores Advanced Auto or Auto Zone will test your starters for free.
DC
DC
Thu, 8/19/10, paul tate
> From: paul tate
> Subject: Re: [anzhonda600owners] Starter problems
> Date: Thursday, August 19, 2010, 2:35 PM
> Good luck with it.
> Paul
> --- On
> Thu, 8/19/10,
> mr
> .n600
> > From: mr.n600
> > Thanks,
> > Mike Valentine
> > (2) '71 Sedans!!
Hi Mike, bad ground is always a common problem. Also check the main fuse, on my Blue coupe the screws were loose and rusty.
Cleaned everything and tightened the screws and it started right up.
> Mike Valentine
> (2) '71 Sedans!!
Thanks for everyone's replies. It probably is a bad ground somewhere.....this car has sat for 15 years and I just haven't gone through everything yet. All I know is that it started up with no issues several weeks ago and now it doesn't. The battery cables are questionable and the main fuse hasn't been checked yet either. I will be playing with it again this weekend and will let you guys know what happens.
Mike Valentine
(2) '71 sedans!!
---------- Original Message ----------
Subject: [anzhonda600owners] Re: Starter problems
Date: Fri, 20 Aug 2010 02:17:23 -0000
Sign up to the #1 voted penny stock newsletter for free today!
AwesomePennyStocks.com
Mike Valentine
(2) '71 sedans!!
Penny Stock Jumping 2000%--- In
> Mike Valentine
> (2) '71 Sedans!!
