Z600: Positive or Negative Ground?
ian_crosley
Post by ian_crosley »
Hello All,
Should the Z600 be wired postive or negative ground?
Thanks!
-Ian
brad fenn
Re: Z600: Positive or Negative Ground?
Post by brad fenn »
It's not a British car!  Negative Ground!
ian_crosley To:
Mon, January 3, 2011 4:34:59 PM Subject:
[anzhonda600owners] Z600: Positive or Negative Ground?
Hello All, Should the Z600 be wired postive or negative ground?
Thanks!
-Ian
Ok Brad, for one, in the early 50's an number of vehicles built world wide had a negative ground.   Most had 6 volt systems and many were built right here in the good old USA.
Ian,
The negative ground wire runs from the negative battery terminal to the Honda 600 body (the bolt is also use to attach the coil) and then to the cam box (passenger side of the engine) bolt.  It must be attached to both the engine and the body.   If you use one of the shroud bolts when attaching it to the engine, make sure it has a metal sleeve inside the rubber grommet so there is metal to metal contact.  Page 57 of the Coupe supplement shop manual has a picture of the cable.  Make sure all surfaces are clean of paint and corrosion for a good connection.
Herman
Post by Herman »
Hey! My mk1 mini cooper is a negative ground.
Sent from my Verizon Wireless BlackBerry
brad fenn
Sender:
Date:
Mon, 3 Jan 2011 20:50:33 -0800 (PST)
ReplyTo:
Re: [anzhonda600owners] Z600: Positive or Negative Ground?
ian_crosley To:
Thanks!
-Ian
Harry Connors
Post by Harry Connors »
I think you meant positive ground as most cars made in the USA had positive ground until the late 40's to early 50's. Basically once the industry started converting to 12 volts they converted to negative ground.
Harry
On 03.01.2011, at 21:08, wrote:
> Ok Brad,
> for one, in the early 50's an number of vehicles built world wide had a negative > ground.   Most had 6 volt systems and many were built right here in > the good old USA.
> Ian,
> The negative ground
> wire runs from the negative battery terminal to the Honda 600 body (the > bolt is also use to attach the coil) and then to the cam box (passenger side of > the engine) bolt.  It must be attached to both the engine and the > body.   If you use one of the shroud bolts when attaching it to the > engine, make sure it has a metal sleeve inside the rubber grommet so there > is metal to metal contact.  Page 57 of the Coupe supplement shop manual has > a picture of the cable.  Make sure all surfaces are clean of paint and > corrosion for a good connection.
> brad
> fenn
> Monday, January 03, 2011 8:51 PM
> ian_crosley
> ian.grout@...
> [anzhonda600owners]
> Hello All,
> ground?
> Thanks!
> -Ian
Kevin Gailey
600 in Yuba City
Post by Kevin Gailey »
Love
Re: 600 in Yuba City
Post by Love »
Contrary to the ad, it may be a factory ragtop (plastic panels instead of cloth headliner).  Price is excellent.  Sacto owners go check it out and tell us more.  IMHO this is the rarest of USA import models (after the automatic).
Bruce D.
Santa Clara CA
Kevin Gailey To:
Sun, January 9, 2011 12:12:56 PM Subject:
[anzhonda600owners] 600 in Yuba City
http://yubasutter.craigslist.org/cto/XXX-XXX-XXXX.html
novak_dean
Post by novak_dean »
I called on this a few weeks ago, and the owner thought it was an aftermarket/cloth thing.. not saying it's a bad deal, but I turned away from it because of the top that "uses snaps to close." Sounded sketchy to me, but maybe good for someone else.. owner was a nice guy- maybe worth looking into if you're in the area..
> Bruce D.
> Santa Clara CA
> From: Kevin Gailey
> Sent: Sun, January 9, 2011 12:12:56 PM
> Subject: [anzhonda600owners] 600 in Yuba City
> From: "billmyong@..."
> Sent: Mon, January 3, 2011 12:08:26 PM
> Subject: RE: [anzhonda600owners] Z600: Positive or Negative Ground?
> good old USA.
> Ian,
]On Behalf Of brad fenn
> Sent: Monday, January 03, 2011 8:51 PM
> Subject: Re: [anzhonda600owners] Z600: Positive or Negative Ground?
> From: ian_crosley
> Sent: Mon, January 3, 2011 4:34:59 PM
> Subject: [anzhonda600owners] Z600: Positive or Negative Ground?
> Hello All,
> Thanks!
> -Ian
Love
Post by Love »
Right you are.   The real deal is a slider with a latch (same as interior door).  Many years ago I went after a ragtop in North Highlands, that unfortunately had been wrecked, without hope of revival, yet the owner still wanted megabucks.
ymmv
Bruce
Santa Clara, CA
novak_dean To:
Mon, January 10, 2011 5:12:12 PM Subject:
[anzhonda600owners] Re: 600 in Yuba City
> Contrary to the ad, it may be a factory ragtop (plastic panels instead of cloth > headliner).�  Price is excellent.�  Sacto owners go check it out and tell us > more.�  IMHO this is the rarest of USA import models (after the automatic).
> Bruce D.
> Santa Clara CA
> From: Kevin Gailey
> negative ground.� �  Most had 6 volt systems and many were built right here in the > good old USA.�
> Ian,
> � � �  The negative ground wire runs from the negative battery� terminal to the > Honda 600 body (the bolt is also use to attach the coil) and then to the cam box > (passenger side of the engine) bolt.�  It must be attached to both the engine and > the body.�  � If you use one of the shroud bolts when attaching it to the > engine,� make sure it has a metal sleeve inside the rubber grommet so there is > metal to metal contact.�  Page 57 of the Coupe supplement shop manual has a > picture of the cable.�  Make sure all surfaces are clean of paint and corrosion > for a good connection.
> It's not a British car!�  Negative Ground!
> From: ian_crosley
> Hello All,
> Thanks!
> -Ian
